330 heads
Old June 28th, 2016, 09:18 PM
Cutlass Fan's Avatar
330 heads
What are the differences between the #1,2,3 & 4 heads on the 330. I saw that they supposedly had a different number head in each year of production.
Cutlass Fan is offline
Old June 28th, 2016, 10:42 PM
Out of Line, Everytime😉
olds 307 and 403's Avatar
#1 had rocker shafts and a 45 degree cam angle. #2 had 3/8" rocker studs, same angle. #3 and #4 had the same 5/16" rocker set up as all later Olds V8's. #3 had the 45 degree cam angle, #4 the 39 degree cam angle like all Olds V8's to 1990.
olds 307 and 403 is online now
Old June 29th, 2016, 01:52 AM
svnt442's Avatar
The heads don't determine the lifter bank angle, the block does.
svnt442 is offline
Old June 29th, 2016, 06:31 AM
Yes, but it means there may be push rod interference if they are put on later blocks.
Old June 29th, 2016, 06:48 AM
^^^This. There are minor variations in the pushrod holes in the heads due to the lifter bank angle.
joe_padavano is offline
Old June 29th, 2016, 07:22 AM
edzolz's Avatar
Also, supposedly, the #4 heads had smaller combustion chambers.
edzolz is online now
Old June 29th, 2016, 07:29 AM
Redog's Avatar
The #4 heads I have at the "WG" heads which are the hi compression heads Not sure if all #4 heads are Hi-Comp heads
Redog is offline
Old June 29th, 2016, 09:28 AM
Every single 1964-1972 SBO head has chambers in the 60cc-66cc range. Variations are more due to manufacturing tolerances and how many times the heads and valves have been cut than due to any design differences. "High Compression" was achieved by changing the piston dish, not the combustion chamber. The no. 8 heads from 1973 were the first SBO heads with different size chambers (approx 80 cc).
Old June 29th, 2016, 10:00 AM
Octania's Avatar
Nice summary.
"HC heads" is probably Chevy-centric voodoo. Olds used variously dished pistons.
Octania is offline
Old June 29th, 2016, 12:25 PM
Thx for the info. I take it they all have similar flow and that it is similar flow to 350 heads.
Old June 29th, 2016, 05:37 PM
My understanding is yes. Same size valves as regular 350 heads and similar ports.
Old June 29th, 2016, 08:16 PM
Good to know, thx.
Old June 30th, 2016, 06:37 AM
oldsmobiledave's Avatar
I disagree with the cc range. It is 64-69 cc not 60-66 cc. Only the #4 heads are 64 cc the others are 68-69 cc as cast.
oldsmobiledave is offline
Old June 30th, 2016, 06:44 AM
Maybe as-designed, but not as-cast. Every Olds head I've ever seen has an as-cast chamber that's larger than the advertised numbers. Until someone performs a survey of chamber volumes with a statistically valid sample size, I'm not going to worry a lot about published numbers. The reality is that a couple of cc's of difference in chamber volume will not be measurable in performance.
Obviously, anyone who is building an Olds motor for performance should properly measure and set chamber volumes, piston heights, dish size, etc, etc. For the vast majority of people who simply want to bolt heads onto their stock or nearly stock motors, they will never see the difference in performance with any #1 through #7A heads. Normal production tolerances everywhere else (not to mention using FelPro blue gaskets) will far outweigh a 4cc chamber difference.
Nor Cal Andy
August 22nd, 2011 07:17 PM
65cutty
October 30th, 2008 08:27 AM
65cutty
August 27th, 2008 10:09 AM
Run to Rund
August 4th, 2008 02:08 PM
DennisG.
May 23rd, 2008 12:00 PM
Quick Reply: 330 heads
