Oddessy batterys
Old April 7th, 2015, 08:15 PM
Chevy budget Olds powered
coppercutlass's Avatar
Oddessy batterys
Ok so i got new battery's for my car and my dad's . decided to go with odyssey's pcm925 . For his car its easy as im using top post adapters with bolts running through them just like the 20 dollar adapters they sell but i made my own and save some coin and time. Im not that cheap but i dont have much time. Any who they come with an m6 thread and instead of using an adapter on mine which cost more since i need the side post adapters im considering running an eyelet for the battery cable with the bolts holding it down. I know many modern cars run terminals like this im just curious if anyone else has used this battery with an eyelet with to the terminal or if there will be any issues. I personally see more issues with an adapter but thats just me.
coppercutlass is offline
Old April 8th, 2015, 02:21 PM
Oldsragger's Avatar
You mean to use this on cables then connecting bolt to the battery? Many makes powerbrackets for battery terminals too, then they can connect many cable terminals on same line. Specially car stereo guys. Odyssey is good batterys
Oldsragger is offline
Old April 8th, 2015, 05:34 PM
Thats the same set up im gonna do as the one you pictured for battery cables . I did do some research and many guys have ran it just like you pictured.
Old April 8th, 2015, 11:39 PM
Oldsragger's Avatar
should not be a problem as long the terminal/positive side can hit the chassie without protecting rubber :P
jfb
May 29th, 2015 07:16 AM
jfb
June 26th, 2013 05:11 PM
Quick Reply: Oddessy batterys
