OL4B intake question
Old February 13th, 2015, 11:20 AM
rickracer's Avatar
Hey guys, I've got a stock 350 with a HEI dizzy and was wondering if an old style OL4B intake would fit with that HEI?
I know an Eddy Performer or Performer RPM will but I'd rather have an OL4B since my internals are stock. I do have an old Offy 360 on her now with a 600 cfm Holley which works fine but that Offy can't be any better than a stock 4bbl iron intake. I want to keep the stock cam so the OL4B seems best.
The more I read about the OL4B the more I think the Performer RPM is the way to go....I can keep adding to the build and have a great intake. Besides that the OL4B is for a spread bore only if I'm correct.
rickracer is offline
Old February 14th, 2015, 03:14 PM
Out of Line, Everytime😉
olds 307 and 403's Avatar
I have seen the OL4B in square bore as well. The RPM intake is good intake that will work OK with a stock motor.
olds 307 and 403 is offline
Old February 15th, 2015, 07:41 AM
cutlassefi's Avatar
Use the Performer RPM, especially with that 600 carb. And don't worry about mixture "velocity" with that intake. Have you seen how small the runners are?
Thanks.
cutlassefi is offline
Old February 18th, 2015, 10:20 AM
rickracer's Avatar
I found this pic on the net, no sure how reliable it is but this OL4B is installed on a 403 with an HEI. Not sure if the 350 and 403 use the same block casting or not.
With the cap installed I'm sure it would need some clearance work on the intake to work. I don't like that little of clearance so going with a RPM might be better.
Old July 16th, 2015, 09:31 AM
oldsmike1972's Avatar
I had to grind on my intake when I was running it. Going from memory, maybe .050-.075 deep, about 2" long and about 0.500 wide.
oldsmike1972 is offline
StickW31
December 28th, 2014 03:03 PM
1978 Oldsmobile Omega
July 7th, 2014 05:14 PM
ihengineer76
May 25th, 2013 06:52 PM
Eightupman
October 12th, 2012 07:05 PM
Shradezz70S
July 28th, 2012 10:01 AM
Quick Reply: OL4B intake question
