rocker arm and studs
Old June 15th, 2014, 10:23 AM
Chevy budget Olds powered
coppercutlass's Avatar
Ok so im pricing out some parts to wrap up the 355 I have been working on for some time. Im Looking at running full roller rockers whats some good alternatives to the Harland sharps. I see proform , scorpion , comp cams , lunati offer options for olds. I really liked the comp cams 17044-16 .
I also need to know what part number for the 7/16 studs I need to run for the olds.
I also need to know what valve springs to use for a cam with 520/544 and 235/244 . Do you think 10 to 1 compression is good for this cam or 10.25 to 1 would be better ? My combo as is will be @ 10.25 to 1 but I would like to be on the safer side to run pump gas 93. I can always get 93 sometimes 92 91 so just throwing caution to the wind.
Thanks in advance guys.
coppercutlass is offline
Old June 15th, 2014, 03:39 PM
Engine Builder
Smitty275's Avatar
You should be fine with that cam and 10.25:1.
I'll be able to tell you more about the ProComp rockers by weeks end. I ordered a set to see what they are like and will be putting them on a bracket motor for a season of durability testing.
I've really heard nothing bad about the other rockers you mentioned. Personally I have only installed one set of Crane which havnt really been put to the test yet. All the rest, for about 30yrs., have been Harland Sharp with excellent results.
Smitty275 is offline
Old June 15th, 2014, 04:47 PM
I know harland sharps are the best . But like always I try to buy with a budget in mind. I don't have an all out race car and there is a big price diffrence between the comps and harlands. I did get a line on a set of harland sharps but they have damage to the area around the pushrod cup the cups look fine.
Old June 15th, 2014, 05:43 PM
Ok here are some pics of the Harland sharps I found . Are these useable yet or too far gone. A total of 5 are damaged as such also near the roller. Im not trying to be a cheap bastard but if these work I can get them a decent price I just don't know what can be re used and not as far as rockers go.
In this pic you can see all 5 .
here is 2 up close.
Old June 15th, 2014, 06:01 PM
brddg's Avatar
looks like they got run and revved without guideplates. I wouldn't chance it, replace those 5.
brddg is offline
Old June 15th, 2014, 06:16 PM
I haven't bought them. I saw them on an ad and I was curious as to it would be safe to buy these and run them or they are too sketchy too run. I really like the comps for the price and I have never had issues with comp cams products. Im really looking forward to what smitty has to say about the procomps.
Old June 15th, 2014, 07:01 PM
cutlassefi's Avatar
[QUOTE=coppercutlass;711080]Comp cams 17044-16. Those are fine for budget rocker.
I also need to know what part number for the 7/16 studs I need to run for the Olds.
SBC, 1.75 stud length on the top side. That way if you use the shorter poly locks you can still fit the stock valve covers on it.
I also need to know what valve springs to use for a cam with 520/544 and 235/244.[QUOTE]
What's the lobe sep on the cam?
cutlassefi is offline
Old June 15th, 2014, 07:11 PM
Its a 110 mark efi . Thanks for chiming in. We may butt heads but I do appreciate it .
Old June 15th, 2014, 07:16 PM
cutlassefi's Avatar
No problem.
110lsa- Then I'd have no problem with the 10.25:1. It has a fair amount of exhaust so it should make power in the upper ranges as well.
Old July 9th, 2014, 09:54 AM
73olds350r's Avatar
Hey guys did anyone find the part number for the rocker studs for the 17044-16 or even the part number for the ones Mark listed for the sbc if so I would be thankful if one would share as im stuck on this.
Thanks in advance for any help Kris
73olds350r is offline
Old July 9th, 2014, 09:57 AM
I found em through summit under small block chevy. I don't have the part number on me at the moment.
Old July 11th, 2014, 05:25 AM
73olds350r's Avatar
Thanks for the reply Copper a few other Questions just to make sure i understand everything so the bottom of the the stud needs to be 5/16 and the top needs to be 7/16 and the total length needs to be 1.75 and its made for small block Chevy is the brand comp cams as well or a another? I been on summit and put the size thought the filters and have not found anything so I must be missing something.
Thanks Kris
Old July 11th, 2014, 10:20 AM
That's because I think we where looking them up for drilled for 7/16 I think or 3/8 not sure on that. When I was looking them up I knew what it was but I guess I lost the links to them. But I think there is possible a mopar stud that is 5\16 base unsure about the top portion width wise and length . I'm sure if you contact cutlassefi he can set you up.
this is what my search lead me to I just punched in all the specs into the summit page as if I where looking up generic studs I wend by base thread effective legth and nut thread size . This was just a quick search so I could be wrong on the link .
https://classicoldsmobile.com/forums...tml#post720637
Delmont 88 PA
March 21st, 2012 04:52 PM
Railguy
December 31st, 2011 07:21 PM
CutlassLegend
September 21st, 2011 02:56 PM
330noob
August 30th, 2011 10:07 PM
defiant1
March 31st, 2011 04:28 AM
Quick Reply: rocker arm and studs
