2016 Buick Olds Cadillac Nats
Old June 30th, 2016, 08:03 AM
Dick Miller's Avatar
Don't forget our 19th annual Race/Show July 24, 2016 at Summit Motorsports Park in Norwalk OH. For more info go to dickmillerracing.com. Thanks, Dick
Dick Miller is offline
Old August 1st, 2016, 09:48 AM
WMACHINES's Avatar
Thank you for the event, even though weather was marginal, I still had a great time. air density was rated at 3400 ft. 87 degrees 71% humidity. Still ran a 11.94 @ 113.75mph
regards
WMACHINES is offline
Old August 2nd, 2016, 05:46 PM
regards
Good seeing you there. Dick
Old August 3rd, 2016, 02:23 PM
BlackGold's Avatar
regards
Great numbers, Mark. I've read about your build before; is your engine still mostly stock?
BlackGold is offline
Old August 4th, 2016, 07:06 PM
WMACHINES's Avatar
Went from hyd tapoet to hyd roller to avoid zinc issue. Bump comp ratio from 10.93 to 11.6 did upgrade pistons and rods while i was at it for strength and weight savings.
davebw31
September 16th, 2016 07:12 AM
davebw31
August 4th, 2014 01:09 PM
BeenThere
February 21st, 2013 10:42 AM
nbfalj
November 14th, 2012 12:33 PM
DeadBang1968
January 19th, 2011 06:35 AM
Quick Reply: 2016 Buick Olds Cadillac Nats
