The go faster thread
Old July 15th, 2015, 06:46 AM
wr1970's Avatar
The question is how fast would you like to go.My goal is deep nines when cash allows.The engine will be a 350D diesel block because it has the .842 lifter bores. I have the block that is standard bore i am leaning to a 434 ci.The car is a 1970 442 tube chassis.Pics of the car is in my album. I didn't post all the pics in the album.There are around 108 pictures of the total rebuild this would a chassis thread like cutlass freak did.Some day i may post them.This car is set up with front plate and mid plate.So lets hear about your goals and how fast you want to go.
wr1970 is offline
Old July 15th, 2015, 10:34 AM
Proud Viet Nam Veteran
redoldsman's Avatar
I have had my 54 a little past 80 but not for long. It does okay around 70. I am just scewing with you but this is the truth.
redoldsman is offline
Old July 15th, 2015, 10:53 AM
wr1970's Avatar
Nothing wrong with having a 54! Is there a reason a little past 80 bothers you or just a cop thing?I like the color of your car.
wr1970 is offline
Old July 15th, 2015, 11:12 AM
chadman's Avatar
I expect my '69 to run mid-upper 9's with a 494 BBO naturally aspirated when completed. As soon as it hits the track I plan to start building the next generation short block which will be a D/DX block 434/440 that I plan to use the same top end off of the 494 and spray enough N20 to get it into the 8's.
chadman is offline
Old July 15th, 2015, 11:22 AM
redoldsman's Avatar
It has bias belted repro tires on it and it is 61 years old. It runs great and has good oil pressure but I just don't want to push it that hard for long. It will probably get a set of wide white radials next year. Thanks for the compliment on the color.
Old July 15th, 2015, 03:12 PM
young olds's Avatar
I don't have enough money to go fast but if I did I'd like my 62 to be a single digit car, maybe low nines. And my 66 will never have a cage but id like it to be 11's
eventually
young olds is offline
Old July 15th, 2015, 04:53 PM
wr1970's Avatar
What size engine is in your 54?
wr1970 is offline
Old July 15th, 2015, 04:56 PM
wr1970's Avatar
eventually
You can run 11.50 without a cage/roll bar at a drag strip.If you go faster they just tell you to go home after a couple break outs. On the street LOL as fast as you want.
wr1970 is offline
Old July 15th, 2015, 07:24 PM
redoldsman's Avatar
In 1954 they stepped the displacement up to 324 cubic inches from 303.
Old July 15th, 2015, 07:48 PM
wr1970's Avatar
It's a good thing i don't own it! It would be duel exhaust with flame throwers. For night fun.
wr1970 is offline
Old July 17th, 2015, 09:11 AM
wr1970's Avatar
So are most of you guys looking to run 12's with a streetcar or faster? Trying to get a gage.I have three recipes all faster than 13.0 and all are 455 engines.If the mods change this forum i will post my builds as well as one other that a buddy has.The 12 eng is very well proven with around a thousand time slips.The others have several hundred passes.
wr1970 is offline
Old July 21st, 2015, 02:39 PM
wr1970's Avatar
At last we having what i have been pushing for to some degree. I should be happy as we now have a place for racing builds.Not totally what i wanted but will have to do for now! Thanks Eric
wr1970 is offline
Octania
March 8th, 2015 03:35 PM
Octania
August 20th, 2013 08:01 PM
70CCV
January 17th, 2013 06:26 PM
Wyze
September 2nd, 2010 07:24 PM
Trooper519
November 18th, 2007 06:18 AM
Quick Reply: The go faster thread
