Engine Builders?
Old June 17th, 2014, 06:16 PM
jRoofgunner's Avatar
Engine Builders?
I need recommendations as to what engine builders I should consider for buying a turn key engine for my 65 Cutlass in the 400 to 455 cid range. I was told not to use Mondello. It would be carburated, and look as stock a reasonably possible. Thanks in advance.
jRoofgunner is offline
Old June 17th, 2014, 06:23 PM
Chevy budget Olds powered
coppercutlass's Avatar
No turn key engines really available but for the same price you can probably have an engine tailored to your needs and performance goals. Member smitty275 and cutlassefi are both resident engine builders by trade contact them. But other shops are rocket racing performance , J&S machine .
coppercutlass is offline
Old June 17th, 2014, 07:18 PM
Boldsmobile's Avatar
There are 3 different Mondello named companies.
Some I wouldn't hesitate to do business with, do some searching.
Boldsmobile is offline
Old June 19th, 2014, 06:11 PM
rubeng442's Avatar
Give BTR a call.
btrperformance.com
rubeng442 is offline
Old June 21st, 2014, 12:13 PM
chadman's Avatar
Call Smitty at M&J Proformance. He is the only Olds specialist I deal with for good reason.
www.mjproformance.com
chadman is offline
Old June 21st, 2014, 04:31 PM
cutlassefi's Avatar
If you can give me a little better idea of exactly what you're looking for and your budget I may be able to help you out.
Thanks.
cutlassefi is offline
Old June 21st, 2014, 05:13 PM
Mr Nick's Avatar
I can vouch for Mark (cutlassefi), he won't steer you wrong. Don't be afraid that he's in FL, shipping is a small cost when you consider a full build price.
Bill BTR http://btrperformance.com/
The GOOD Mondello http://mondello.com/JoeMondelloRacingEngines.php
The BAD Mondello http://www.mondellotwister.com/
Mr Nick is offline
Old June 24th, 2014, 05:14 AM
11.52 @116
jims2000lt's Avatar
Rhyne Competition Engines does my machine work. All my parts usually come from Rocket Racing. John is always great to talk to.
jims2000lt is offline
Old June 24th, 2014, 03:40 PM
Engine Builder
Smitty275's Avatar
Here is my advice for the OP. Contact the shops you hear good things about. Starting with the one closest to home. Have your goals laid out that the build must achieve. Then through your gut feelings about the information you receive back from those you contact narrow it down to two. Call them again and see how you get treated the second time around. If you like guy closest to home then that's a 'no brainer'. If your choosing between a pair that has to ship to you then pick the one your most comfortable with.
You will probably eliminate a few just because they don't respond to your email or return your call.
I, M&J ProFormance, as well as others on that list are highly capable of building you a high quality engine that will give you 100,000 miles of service if you take care of it. But we each have different personalities of which you may or may not wish to deal with.
Smitty275 is offline
Old October 17th, 2014, 06:42 PM
Adam442's Avatar
Btr performance
Bill Travato - he literally wrote the book on the olds V8 - pick it up at Barnes and noble it's a great read before you decide anyway.
Adam442 is offline
Old October 17th, 2014, 08:20 PM
69ishHoliday's Avatar
I'm glad this thread was brought back up, seems like good resources named here.
69ishHoliday is offline
Old October 18th, 2014, 06:23 AM
I'm going to track down that book. A couple of things regarding Olds engines that knowledgeable people have told me. We had a 65 Cutlass with the 330 4bbl that Mom and Dad bought in 1965 from Pristows, in Winber, PA. There was a guy named Pappy Wilson (he was in his 50's in the late 60's). He was one of the original hot rodders and build racing engines in the 50's and 60's. He told my Dad all the car needed was to jump the timing a few degrees and the Olds people did their homework when they built that motor. Another mech, who did street racing tore one of those engines down and confirmed that it was not a mild factory motor just by the cam, pistons and valves that were in it. I ran into an older fellow at a Good Guys car show in Kansas City when I showed my 70 442. He told me, "we had better blocks in those cars because Olds put more nickle in the steel than the other three." To bad Olds is gone and there's no more individuality. Sure glad I grew up during that time. Beats the hell out of texting.
Old October 18th, 2014, 06:58 AM
george landis's Avatar
Engine builder
Did you get an engine? Whom did you purchase from? Good communications? Cutlassefi returns your calls and is very easy to talk with. The loyal are keeping the Oldsmobile brand alive.
george landis is offline
Old October 18th, 2014, 07:13 AM
George,
Not yet. Right now I'm rebuilding the front suspension. I contacted Mondello of Crossville, TN and said I was interested in a 425/455 motor. No specifics were discussed. They got back to me and I said I was in no hurry at this point and that I wanted to talk to them face to face and they said to stop by their shop, which I plan to do. I can also speak with others and will entertain CutlassFi also. It's just at this point I have enough to keep me busy and since I'm retired I plan on "holing up this winter", not going anywhere, and just work on the car. One thing at a time!
Old October 18th, 2014, 10:24 AM
Adam442's Avatar
Amazon has the book
The book is called Oldsmobile V8's and Amazon has it also - bill is finishing up mine this month - 496 580hp 675tq
Adam442 is offline
JSGD1966
June 10th, 2018 09:19 PM
350TurBRO
September 9th, 2014 07:09 AM
Brgrenier
August 25th, 2014 10:26 AM
MDchanic
February 25th, 2014 11:42 PM
jdana24
September 21st, 2011 12:02 AM
Quick Reply: Engine Builders?
