Cometic MLS for 455 with 1/2" head bolts?
Old April 5th, 2020, 06:36 AM
Saresks's Avatar
Hi,
if somebody has experience,
I'm planning to get Cometic MLS head gaskets C5811-036 advertised for 455 engine, and using them in small block, heads and threads converted for 1/2" head studs. How tight are Cometics bolt holes? Any problems with that?
Thank you,
Sami
Saresks is offline
Old April 5th, 2020, 08:42 AM
svnt442's Avatar
Originally Posted by Saresks
Hi,
Thank you,
Sami
The same gaskets are listed for the 1977 350 that came with ½" bolts, so you should be just fine.
svnt442 is offline
Old April 5th, 2020, 08:55 AM
Saresks's Avatar
Great, thanks a lot!
Saresks is offline
Old April 6th, 2020, 06:00 AM
Run to Rund's Avatar
I just checked a Cometic .027" big block Olds head gasket. It has plenty of clearance for 1/2 inch head bolts, and comes with the alignment tabs for both BBO and SBO.
Run to Rund is offline
Old April 6th, 2020, 06:50 AM
oddball's Avatar
Yup, I've used a few different cometic patterns (the first chunk of their part number is the pattern). All are set up for 1/2" bolts.
oddball is offline
ohiocutlassparts
January 15th, 2014 04:36 PM
taa442
June 22nd, 2012 01:08 AM
boondocker
June 18th, 2011 12:29 PM
greenslade
January 27th, 2010 06:42 AM
dman0712
December 11th, 2009 07:33 PM
Quick Reply: Cometic MLS for 455 with 1/2" head bolts?
