Big Block Slap in the Face
Old May 7th, 2012, 07:55 PM
  #41
Chevy budget Olds powered
coppercutlass's Avatar
how much for the rockers . Im intrested to an extent funds being the base of my issues lol .
coppercutlass is offline
Old May 7th, 2012, 08:13 PM
  #42
ah64pilot's Avatar
Mondello sells them for $350...I'll sell for $250 shipped. They will be brand new, but I wouldn't advise using them on anything that is reaching the max spring lift.
I've got .574" lift, my valve springs max lift is .575" so I think the open pressure is what broke them. They should be fine on a milder engine...but I make no claims as to where they are made or by whom. They are Mondello rocker arms made by wherever they bought them from. If you're interested let me know. As soon as they arrive I can ship them to you.
ah64pilot is offline
Old May 7th, 2012, 08:19 PM
  #43
i can only go to 550 max i cant afford them at the moment. I got stuff at the machine shop and i may have to rebuild a trans here soon.
Old May 7th, 2012, 08:42 PM
  #44
ah64pilot's Avatar
How close can you get? I'm all ears and don't really have a use for 2 sets of rockers for one car lol!
Old May 9th, 2012, 06:41 AM
  #45
507OLDS's Avatar
Those pivots look too thin,as if they should have been drilled for a smaller 3/8 stud,instead of 7/16.
Harland Sharp was supplying Mondello years ago,but I think they have since cut ties.The 7200 rockers that Mondello sold,were Harland Sharps.I would order direct from Harlans Sharp,also known as Custom Speed,if you give them a local visit.They always have some cool stuff going on there,and they were able to make some custom ratios for me before.
507OLDS is offline
Old May 10th, 2012, 05:17 PM
  #46
ah64pilot's Avatar
I ordered from HS 2 weeks ago...they had to make the rockers, they were out of stock. They shipped today I also got 2 new rocker studs on order to replace the two that were damaged. Should be up and running within a week...track day as soon as she's up.
Old May 15th, 2012, 07:01 PM
  #47
ah64pilot's Avatar
Ok, the new rockers are in...both the Harland Sharps I paid for and the replacements from Mondello. I'm going to use the Harland Sharps and will sell the Mondello replacements. Here are the pics for a comparison:
Mondello Replacements:
Harland Sharps:
I also got a complete set of 3/8" pushrods that they sent me even though they had already sent them a few weeks ago. I even put a note in my return for them NOT to send pushrods...oh well, it's no wonder they are having problems.
Old May 16th, 2012, 04:56 AM
  #48
507OLDS's Avatar
That Harland Sharp rocker is their new design,and a better one.The ones that are flat on top are the older design.
507OLDS is offline
Old November 16th, 2014, 04:58 AM
  #49
Rodney
cdrod's Avatar
Hs s50026a
Sorry to dig up an old thread, but really need some guidance on rocker selection. What do you guys think about the Harlan Sharp S50026A pedestal style rockers for a mild street build? I have some ProComp heads w/Edelbrock valves and plan to build a stroked sbo for my daily driver (not planning to race this car). I have not selected a cam yet but don't think valve lift would be more than .500". I've been told you need to remove the oil baffles in the stock valve covers to clear the polylocks with HS rockers. Would the S50026A rockers fit under the stock covers without modifcations? Thanks!
cdrod is offline
Old November 16th, 2014, 06:19 AM
  #50
cutlassefi's Avatar
The studs for the HS rockers won't work on the Procomp heads, wrong size.
Just buy a good 1.6 rocker, BBC studs(1.75 effective length), and the short poly locks from Comp and it'll fit under the stock valve covers.
cutlassefi is online now
Old November 16th, 2014, 06:46 PM
  #51
Rodney
cdrod's Avatar
I bought a set of ProComp heads from a guy that never built his motor. The heads were built by Bernard Mondello and came with some purple rockers from Howards Cams. I think they are Ford style rockers. Can I run these with the shorter poly locks and clear the stock valve covers?
cdrod is offline
Old November 17th, 2014, 04:16 AM
  #52
cutlassefi's Avatar
Yes if they're Ford style rockers. But you'll still need the shorter studs as well.
Old November 18th, 2014, 06:44 AM
  #53
Rodney
cdrod's Avatar
Mark:
Thanks for the info. I called Bernard Mondello yesterday to get some more info on these heads. He confirmed the purple rockers are the Ford style for Windsor engines.
cdrod is offline
Old November 21st, 2014, 07:51 AM
  #54
real57vetteguy's Avatar
re
I actually had a different issue but I figured it would add to the conversation seeing this was also with Ford style roller rockers.
When I first bought my 468 it was a low mile build, when It arrived during inspection I noticed one of the valves was worn over to one side what I considered to be excessively for the mileage, then we found the roller pin laying in the corner of the head, after checking them all out there was one broken roller pin and two cracked. They were a PSP brand if memory serves me!
real57vetteguy is offline
bocoogto
August 26th, 2023 06:09 PM
ragtop70
September 3rd, 2012 10:15 AM
Jaybird
March 18th, 2011 07:05 PM
olds4life
February 9th, 2010 08:48 AM
NEWOLDSMAN
November 17th, 2009 12:19 PM
Quick Reply: Big Block Slap in the Face
