70-72 Cutlass 4 Speed Parts
Old May 30th, 2011, 12:40 PM
72442clone's Avatar
Hello, I'm going to be swapping my TH400 to a M22W Muncie very soon. I found all of the parts remanufactured or aftermarket, but would like them to be GM parts if at all possible.
Let me know what you have for me, where you are, and provide pics if possible.
List of parts needed: clutch/brake pedal assembly, z-bar, z-bar frame bracket, clutch pedal pushrod, pushrod boot and retainer, clutch fork boot, clutch fork, adjustable clutch fork pushrod, clutch fork ball, clutch return spring, z-bar hardware, flywheel, bellhousing, console insert/boot for shifter, hurst shifter with ****, shift linkages, steering column plate and seal, neutral safety/reverse light switch, 2 piece woodgrain trim for manual console.
72442clone is offline
Old May 30th, 2011, 01:19 PM
skryla's Avatar
Check with Brian Trick, I think he goes by 507OLDS
skryla is offline
oldspackrat
September 8th, 2015 09:25 PM
halfmoontrail
June 22nd, 2013 09:41 AM
Big Mikey
March 27th, 2013 06:51 AM
joynerz
July 25th, 2012 07:34 AM
ilde
February 7th, 2008 10:21 AM
Quick Reply: 70-72 Cutlass 4 Speed Parts
