Seeking 1949-1955 Olds Manual trans Flywheel
Seeking /Looking for a supplier / vendor for Flywheel / pressure plate / clutch for 1950-1955 olds Manual 3 speed transmission .for 303 -324 engine..Im in N Illinois ..Thanks
There were two different flywheels used in the 1950 thru 1955 era.
A 145 tooth flywheel was used from 1950 thru 1953.
A 176 tooth flywheel was used from 1954 thru 1956.
What year engine do you need this for?
According to that number stamped on the block, it is a 1953.
The transmission in your pictures is a 1950 Olds stick shift. (Cadillac built)
In any case you will need to find a 145 tooth flywheel.
December 2nd, 2023 09:45 AM
WyldWilly
November 11th, 2023 07:25 AM
Shot Gun Rich
July 7th, 2014 11:34 AM
