rear speakers
If you want a 10 ohm 6X9 for a factory radio, you can go to your local GM dealer and order them new. If you tell them it is for a 2004 Cavalier with the standard stereo package they will work. You will need to solder a different connector to work with the factory wiring. They are about $20 a speaker.
Or hit the local yarde de junque and get a pair for 10 or so if original style is not important.
Are you looking for real original style with AlNiCo magnets, reconed originals or virgins?
Depends on your resto level...
I would really like the originals if possible-Ihave the AM radio, and the car came with 2 backspeakers
Thanx tomsw31, I will keep that in mind....
I used a replacement 4x10 speaker with a neodymium magnet for the front dash, and wasn't really pleased with the sound quality. Maybe there's another choice out there for your rear speaker application.
Checkout turnswitch.com, correct ohmage frt + rr Made in USA vintage size speakers. I've used them, superior to factory speakers. They will include a ground wire to hook up single terminal RR speakers.
Lady72nRob71
May 25th, 2013 12:09 PM
