Radiator/Fan Shroud Brackets
I need fan shroud brackets to fit a 1970 Oldsmobile 442 w/455 engine. I would also like the brackets for a 4 row radiator. If you can help, please let me know. Thank you.
I am amazed these are not reproduced by someone.
If you mean the metal saddles that the radiator sits in (with rubber cushions inside), then the Parts Place in Chicago has those. If you mean the small tabs welded to the bottom of the radiator support that you bolt the bottom of the fan shroud to, then Inline Tube in Michigan makes those.
1k442
June 6th, 2013 10:59 AM
Giddy
March 10th, 2009 11:37 AM
