Need help with lower control arm bolts
Old May 18th, 2008, 08:05 AM
Seasoned beater pilot.
J-(Chicago)'s Avatar
Does anyone have a pair of front end lower control arm bolts they could spare? These are the big ones with the special taper that hold the arm to the frame mounting points. I'm going to have to oxyacetelene one of mine off and would like to get the suspension put back on memorial day weekend.
J-(Chicago) is offline
Old May 18th, 2008, 08:14 PM
2blu442's Avatar
I'm thinking this is for your Delta. What years or models do you think would interchange? John
2blu442 is online now
Old May 18th, 2008, 09:11 PM
Yes sir, for the delta. I know that 80's G body ones are the same, but as I said I could probably get anything to work for me so long as it's the correct length and grade 10.5.
I'll measure it for you and we'll go from there. There is a taper on these bolts and any aftermarket ones I found today did not have the taper.
I'll get a caliper and measure the diameter of the tapers tomorrow
Old May 19th, 2008, 12:26 PM
Any 77-90 B-body (or C-body or D-body) or 78-88 G-body will work.
joe_padavano is offline
Old May 29th, 2008, 09:16 PM
Joe I have something for one of your future tech pages.
The 81-88 gbody bolts are too small. Let me know if you want exact measurements and comparisons. The shaft is significantly thinner, there is barely any taper on them, and the bolt head sizes on the gbodies are 18mm as opposed to the delta's 13/16'' heads
Old May 29th, 2008, 09:20 PM
2blu442's Avatar
Bolts
Jeremy, are you still looking for these?
Old May 29th, 2008, 09:35 PM
Well... yes and no I guess.
I discovered that my rear control arm bolts were the same as the front ones, so I pirated them from the back and put the front suspension together with the rear bolts lol.
I went to the hardware store today and got some Grade 8s that may do the trick for holding the rear end in, but I wouldn't mind having the correct set of grade 10.9's.
I don't want anyone to have to go out of their way to remove some for me, because it immobilizes their parts vehicles, and are a royal pain to remove.
I don't wish misery upon anyone. This seems like it would be one of those favors you do for someone and totally regret it once you've started.
Old May 30th, 2008, 05:00 AM
Past Administrator
Oldsguy's Avatar
Hate to sound like a goon but did you check ARP?
Oldsguy is offline
Old February 5th, 2009, 09:02 AM
monzaz's Avatar
bolts
So this is so late I have the bolts from rears I always part out. How many do you need. I still need the caliper diameter dimension so I get the right ones for you. Ok? Jim
J D Race.com
monzaz is offline
Old February 5th, 2009, 05:05 PM
Thanks for the offer Monzaz. It's supposed to get into the 40's this weekend , so I'll get out there and take one out for you.
nolabigdawg
October 25th, 2014 11:50 AM
Oldssupreme
February 6th, 2013 12:39 AM
Intragration
October 14th, 2012 10:12 AM
J/O
April 25th, 2012 03:09 PM
72CUTTY
August 22nd, 2008 08:30 AM
Quick Reply: Need help with lower control arm bolts
