Looking for Transmission Slip Yoke for TH350
Old May 20th, 2013, 01:40 PM
ddd777's Avatar
Question Looking for Transmission Slip Yoke for TH350
Looking for Transmission Slip Yoke for TH350 (72 Cutlass)
27 Splines.
I measured it to be 4 3/4"
The one OPGI sells (and is not in stock this week) they have listed at 4.875"
http://www.opgi.com/cutlass/1972/dri...yokes/C240117/
However, it has Outside Snap Rings.
Mine (original to the car) clearly has Inside Snap Rings (see attached image)
Confused and in need of a part....
ddd777 is offline
Old May 20th, 2013, 06:46 PM
AzChevs's Avatar
That is a weird size, I have 3 that I found and they all measure 6 1/2 inches in total length. The rest of everything are the same.
AzChevs is offline
Old May 21st, 2013, 07:06 AM
lemoldsnut's Avatar
I went and looked I don't have one that long either. The longest I have is 4 1/4. Just an FYI the outside clip yoke is for Chevy inside clip is other GM cars. There is a u joint made that is inside clip on one side and outside clip on the other.
lemoldsnut is offline
Old May 21st, 2013, 07:12 AM
ddd777's Avatar
So do you mean the one that OPGI sells (back in stock today, it seems) is meant for Chevy, is the correct length, but I would need an adaptor u-joint?
ddd777 is offline
Old May 21st, 2013, 07:15 AM
lemoldsnut's Avatar
If your driveline has the inside clip type u joint. (factory that was a injected plastic clip) and the yoke they sell is an outside clip like Chevy used then yes you will need the hybrid Ujoint.
Old May 21st, 2013, 07:16 AM
lemoldsnut's Avatar
Did you check your local transmission shops, driveline shops and parts stores to see if the yoke was available new locally? you might be surprised.
Old May 21st, 2013, 11:17 AM
Olds24's Avatar
I have one that you need, All dimensions correct. Check PM
Olds24 is offline
Old May 23rd, 2013, 06:59 PM
sacloc's Avatar
i have 2, all dimensions match
sacloc is offline
Old May 24th, 2013, 10:40 AM
ddd777's Avatar
part located
part located and acquired.
thank you.
ddd777 is offline
Old June 17th, 2019, 10:36 AM
hackmansr's Avatar
I have a similar issue on my 69 Cutlass TH350 slip yoke. It measures 5.00 inches from the center of the cup to the end of the yoke, and it is the inside c clips. I have checked everywhere and am told they no longer make any that length. I found one that is 5 1/2 inches long and was told that is could be cut down. Has anyone ever had one cut down, or does anyone know of anyone that sells the correct length?
hackmansr is offline
Old June 17th, 2019, 11:42 AM
Head to your nearest salvage yard. The 4L60 and 2004R, and most RWD manual transmissions use the same 27 spline yoke. Maybe one of them use the correct length. And even if they don’t, as long as the spline engagement is the same, I don’t see why you couldn’t cut one to the correct length. Deburr the cut edges, make sure it moves freely on the output shaft, should work. The get some U-joints that fit the yoke. I think all the replacements joints have grooves for clips inside the yoke.
matt69olds is offline
67w30
October 15th, 2023 07:54 AM
Bassemaa93
July 19th, 2016 08:02 AM
sadisticsavage
January 11th, 2014 11:06 AM
dfire25
Drivetrain/Differentials
September 24th, 2013 08:02 PM
fitter bill
June 29th, 2011 07:56 PM
Quick Reply: Looking for Transmission Slip Yoke for TH350
