77 442 int pieces
77 442 int pieces
looking for some interior pieces,inside upper windshield trim,pass side trim piece that goes fron a pillar to seat belt at roof,also 2 seat back plastic,both lower door panels for manual windows., prefer white, or light color that can paint white.
Figured you'd be searching for interior replacements at some point. I'll ask around and see if my buddies have anything in they're collections.
I will say, the white trim pieces in very good condition, are going to be a challenge to locate. Like yours, most pieces in white are brittle, chalky, or deteriorating. They're out there but it may take time to track them down.
You'll probably have better luck locating light color or black pieces and then dyeing/painting them to match.
I believe reproduction aftermarket (73-77 Pontiac) seat backs are available, although you may have to modify them to fit. Also, I don't know if they're available in white.
If you can't find white trim pcs, I've got a light buckskin colored upper windshield trim. Got a pair of light blue trim pcs that go above the door glass (A pillar to sail panel trim). Not interested in separating the RH as I already have an orphan LH. Have a pair of light blue lower door panels w/carpet strip. Plastic is a little dry on them...but, good candidates for a re-paint.
GoodOldsGuyDougie
March 4th, 2009 04:35 PM
72rocket
August 2nd, 2007 06:06 PM
