68' 442 Flywheel Cover
Old August 23rd, 2015, 08:01 AM
ezman604's Avatar
68' 442 Flywheel Cover (Found one...thanks)
I've posted a few things in the Wanted section. Thought I'd just ask here if anyone knew of an OEM or aftermarket supplier for the flywheel cover for the 68' 442. I ordered from YearOne (listed as it would fit) but it is a Mr. Gasket chrome plated for Chevy. Starter slot on wrong side.
Calling their techline says they do not carry one to fit. Need one for BOP fitment.
Thanks,
Dave
ezman604 is offline
Old September 1st, 2015, 01:26 PM
ezman604's Avatar
Nobody???
ezman604 is offline
Old September 1st, 2015, 02:03 PM
slaughter442's Avatar
Bell Housing
I have 1 or two laying around One real nice with clutch arm and flywheel. 355 4 pin posi low mile car super clean $450 If I Can Help Just Let Me Know Thanks Darren rocketrat442@yahoo.com
slaughter442 is offline
Old September 1st, 2015, 02:12 PM
I moved your post to the parts wanted section, you'll have better luck finding one. I'm assuming your looking for an inspection cover for an automatic.
oldcutlass is offline
Old September 1st, 2015, 02:14 PM
ezman604's Avatar
Thanks and yes, inspection cover for an automatic. I've always called them the flywheel cover though...for an automatic.
ezman604 is offline
Old September 1st, 2015, 03:10 PM
Octania's Avatar
just turn it around and the starter slot will be on the correct side
:-0
Octania is offline
Old September 1st, 2015, 07:04 PM
67442nut's Avatar
Is it metal or plastic on the '68?
I have the metal ones like came on the '67.
67442nut is offline
Old September 1st, 2015, 07:16 PM
ezman604's Avatar
I'll have to look in the builders manual unless someone already knows for sure.
ezman604 is offline
Old September 2nd, 2015, 04:22 AM
ROCKETMAN269V's Avatar
Flexplate cover
Originally Posted by 67442nut
is it metal or plastic on the '68?
DEFINITELY steel.
ROCKETMAN269V is online now
Old September 2nd, 2015, 06:18 PM
Octania's Avatar
I have some handy but they are always too dented, too rusty, and/or too pricey
Octania is offline
Old September 5th, 2015, 10:22 AM
DR_DAN's Avatar
I have several dust covers. $65 shipped. I know they were removed from 350/400 trans cars, but don`t know if they are the same. If you can measure from mounting bolt to bolt cross ways, I can measure mine to make sure they will fit
DR_DAN is offline
Old September 5th, 2015, 11:52 AM
ezman604's Avatar
Thanks Dan, I have one on the way.
ezman604 is offline
Pacecar
August 8th, 2012 04:40 AM
VikingBlue
June 4th, 2010 03:07 AM
JSGD1966
June 14th, 2009 03:54 PM
JSGD1966
June 1st, 2009 10:50 AM
Jokers69
October 5th, 2006 03:00 AM
Quick Reply: 68' 442 Flywheel Cover
