66 67 3 core radiator
Old November 8th, 2013, 12:38 PM
Looking for 3 core ac / hd cooling stock radiator for a 66-67 Cutlass.
Can be in "re-corable" condition.
Thanks.
Koda is online now
Old November 8th, 2013, 01:40 PM
2blu442's Avatar
I've got several that would fit, may not have the factory codes for your car. Here's a link to the parts for sale ad I created a while back. John
https://classicoldsmobile.com/forums...-shipping.html
2blu442 is offline
Old November 8th, 2013, 01:51 PM
I'd be interested in one that would fit. I am not quite sure what code I would need. I will try the wildaboutcars resource later on, but harrison tanks with no stamped numbers, or even the wrong numbers, would probably be ok. My current auto zone special doesn't let the cap fit well, you have to fit the edge under the lip of the radiator top hold down plate. If the radiator we decide on is indeed confirmed busted, the sawzall method of shipping would be ok.
Thanks.
Koda is online now
Old November 8th, 2013, 03:01 PM
2blu442's Avatar
If your not concerned about the codes I'm sure I've got some Harrison radiators that would fit. Attached are photos of my 1967 Cutlass and how the factory radiator fill looks. I'll take some measurements to be sure and send you some photos of an extra one that would work. John
2blu442 is offline
Old November 8th, 2013, 04:56 PM
Just the facts...
BILL DEMMER's Avatar
a '67 delta radiator will just fit also, you will need to modify the top and bottom mounts though. they had a higher fins per inch count. iirc, it was ~double for a factory radiator.
bill
BILL DEMMER is offline
Old November 8th, 2013, 05:18 PM
ferndaleflyer's Avatar
Where are you located---I just might have a GOOD 67 Radiator here in NC
ferndaleflyer is offline
Old November 8th, 2013, 06:38 PM
Ferndale, Evansville, IN
Bill, thanks. I'll try the A body one first, but that's an alternative.
Blue, those are awesome pictures. My advance auto one, wish I had a picture, has the cap not tilted as much, so the ear of the cap goes under that plate as it goes by.
http://shop.advanceautoparts.com/web...14922|L2*15022
The assembly manual is a little vague, but it seems like VW, VX, VM, and VU were used codes out of a bunch of V and some other letter codes. I can't seem to figure it out. Maybe the car will make it some day to some show where that matters, but I'd just like A factory correct radiator for a 442 with AC, which calls for the HD cooling option; the car won't know what tag it has.
Koda is online now
Old November 11th, 2013, 06:51 PM
Bumpity.
Koda is online now
Alex72cutty
April 21st, 2015 10:30 AM
rcktdoc
July 14th, 2014 12:38 PM
59Olds98
August 14th, 2013 09:38 AM
L69
May 19th, 2013 11:01 AM
kevdog442
January 3rd, 2009 03:21 PM
Quick Reply: 66 67 3 core radiator
