407567 455 Intake
Old March 15th, 2017, 03:30 PM
4R5
4R5's Avatar
407567 455 Intake
Hi, I had posted previously looking for a 404521 “L” iron 455 intake, but further research says that the 407567 is correct for a '71 455 A or B body with T400. 442.com says the 407567 is for stick only '70 thru '72 and 404521 is auto '70 thru '72, but my '72 parts book shows the 404521 for 70, 407567 for '71 and 231399 (never heard of this one) on the '72s. Looking for one with a date code between 125 to 155. Thanks!
4R5 is online now
Old March 15th, 2017, 03:34 PM
442crzy's Avatar
Intake 71 455
PM sent
442crzy is offline
Old March 16th, 2017, 01:36 PM
ROCKETMAN269V's Avatar
Originally Posted by 4R5
......442.com says.......404521 is auto '70 thru '72.........
From the 442.com FAQ: L 404521 '70-'72 455 4V AT and MT. W-33, 442, SX, 88, 98's. Except W-30. Iron.
ROCKETMAN269V is offline
Old March 16th, 2017, 03:14 PM
4R5
4R5's Avatar
Got it, but my '72 parts book shows the 404521 for 70, 407567 for '71. I'm not confident 442.com is 100% accurate.
4R5 is online now
Old March 16th, 2017, 03:23 PM
MOTORHEAD
11971four4two's Avatar
I thought the $ 4 speed intake had a "nipple" for PcV drilled / installed to the front of carb. Same cast Iron manifold. Just no nips for automatic cars
When I get a chance I will look under hood of 1971 and see what casting #'s I can find
Happy motoring
b
11971four4two is online now
Old March 17th, 2017, 07:05 AM
Don't confuse casting numbers with part numbers. For example, 404521 is the casting number for the 1970 intake and is also the part number for the 1970 AT intake. The 1970 MT intake is the same casting number but has the PCV nipple, so the PART NUMBER is 404848.
Imagine that...
According to the 1971 Engine Assembly Manual, the intake casting number is 407567, which is also the P/N for the AT version. The MT version uses that same casting number but has the nipple so P/N is 407568.
joe_padavano is offline
Old March 17th, 2017, 07:17 AM
4R5
4R5's Avatar
Thanks Joe, I appreciate the info! Yes, I am aware of the part # vs. casting #. I had seen a picture here on CO of a '71 intake with the 407567 casting #. But as I mentioned I was led to believe the 404521 was the correct # for my 71 VC (455 4bbl). So I'm going to conclude that I need the 407567.
On a side note, is the Engine Assembly manual available as a reprint? I see it's referenced in section 6 of the Car Assembly manual, but have never seen one.
4R5 is online now
Old March 17th, 2017, 07:44 AM
Here ya go (scroll to Post #9)
https://classicoldsmobile.com/forums...tml#post856534
Old March 30th, 2017, 10:56 AM
4R5
4R5's Avatar
Bump, still looking, thanks!
4R5 is online now
Old March 30th, 2017, 02:55 PM
442crzy's Avatar
Intake manifold
I have no problem taking the one off the engine, lmk if that works for you, thanks
442crzy is offline
January 23rd, 2016 06:48 AM
lunaboy
October 15th, 2015 07:09 AM
brandon reynolds
December 14th, 2013 01:09 PM
507OLDS
October 18th, 2012 07:56 PM
svnt442
July 17th, 2011 04:43 PM
Quick Reply: 407567 455 Intake
