1972 Cutlass 350ci manifold heat riser bracket
As the title states, I need the exhaust heat riser bracket that holds the tube off the air cleaner and the air cleaner assembly for a 72 350ci motor.
Shipping needed to 02115.
Well I'm not sure to be honest.
I can't find anyone around that will rebuild an Edelbrock Carburetor, so it seems I'm going to have o have the quadrajet rebuilt. But if I swap back to the Q-Jet and the stock intake, I won't have an air cleaner that fits around the HEI ignition.
I'm guessing tha like 73/74 cars had HEI ignition. Maybe it was later, 75/76. But they would have to be offset in order to fit around them.
Unless someone has a 72 Air Cleaner (top and bottom), that maybe isn't perfect, but still presentable, then I could try to notch it out, to make it fit.
1977 Delta 88 Flint
December 24th, 2012 11:25 PM
ROCKET VAPOR
October 20th, 2011 11:35 AM
