1968 cutlass power antenna ecutscheon and interior headliner side moldings
A friend is looking for a very nice power antenna ecutscheon that sits on top of the quarter panel. Its the bottom piece that sits oon top of the gasket nd then the top piece which is threaded and has two notches that is used to tighten it down. His are pitted and flaking. Also good straight dent free anodized headliner strips that run from the visors to sail panels.
2 door has a "V" on the bottom and straddles the peak break. 4 door/vert one is angled with a single break which mirrors the panel. I used a big car one for my convertible. The angle seemed slightly different than the 4 door/convertible but you can't tell the difference once it was installed. Henry could probably tell you if they are definitely different
edit:
I just checked Ames and they reproduce the part for a 68-69 GTO but there isn't a picture of it. You might want to call them
This is what is needed. The larger base piece has a #400017 on the underside.antenna.jpgantenna2.jpg
If you ever find one, I would like to purchase or borrow your old pieces for a guide to have some machined out of aluminum. No one is reproducing these and they are very hard to find . Thanks, Charles
X3 on someone reproducing these. The power antennas aren't too tough to find since they were used on many GM cars of the era, but those chrome spacers are Olds specific and pretty scarce. #400017 for hardtop & post coupe, #400018 for convertible & 4 door, 1968-69
72455442RA
August 14th, 2015 07:02 PM
197064buickspec
August 4th, 2014 12:26 PM
allwood2006
November 12th, 2009 11:52 AM
