1965 starfire sheetmetal
Hi, Haven't been on this site for a long time. Need some help with the lower windshield sheet metal. It is rusted and needs to be replaced. Any Ideas,thoughts apreciated. Soooo I think I am looking for a parts car or someone to cut one up for me, I think any full size 1965 olds would work.
ED
ED
My parts book shows same windshield part # for all 65-68 Oldsmobile B/C hardtop bodies, so you should be able to use a piece from any 1965-68 GM B/C 2 or 4 door hardtop, and possibly from other body styles. The difference was usually at the top of the windshield. I'm bound to think the cowl section was the same on them all as the outer sheetmetal is the same.
Just be aware that if the donor piece comes from a big Chevy the price is liable to go up.
1965 Olds Full Size Parts
While I don't have anything used / pieces of car -- I do have mountains of parts for the 1965 - 1970 Olds Full Size cars-----
brakes, drums, master & wheel cylinders, brake hoses, bearings & seals, brake cables,
entire front ends -- ball joints & bushings, tie rods, center links & idler arms, coil springs & shocks.
motor mounts, water pumps, fuel pumps,
ignition & electrical and much more.....
Best to call me -- Craig -- 516 - 485 - 1935......
