1965 Delta/Dynamic Front Wheel Hub
Hey All, I'm Looking to see if anyone has a front wheel hub for my 65 for sale. If In/Near California even better! I can't find one nearby and I need if severely for my daily. Thanks!
No I was extremely fortunate that it Come out relitively un scathed, thought if I had to drive it any long that might not have been the case
The hub is different because the bolt pattern on the Olds is 5" on5 . The Chevy is 4 & 3/4" on 5. the inner wheel bearings are different too so I would have to say that the spindles would be different too.
Maybe someone with a Hollender interchange manual will chime in and can tell you what else might interchange.
Olds, Pontiac and Buick shared little chassis parts interchangability with Chevy in full size cars before 1971.
So, Mike as we talked yesterday. Hub/and drum. I will pull one for you today and inspect it as we discussed.
Per Hollander there is an early and a late hub size. One is 1 25/32" Early, and the late is 2 5/64" So make sure you check that and I will too.
My car has a build date of 04A so most likely a late. But, as I said I will check today.
Larry
Larry
marxjunk
February 24th, 2015 06:45 PM
akins2000
February 14th, 2012 01:09 PM
