Oldsmobile Valve cover casting patterns
Old October 25th, 2012, 01:43 PM
Shoveling Snow
Hairy Olds's Avatar
I have the pattern's to make the mold's from the Sharp valve cover I was selling. The first one is different in the center pad, it is larger then the final design.
The pattern's are made from a solid block of epoxy material and milled to the shape as seen. The epoxy is then attached to a 1/2 inch solid aluminum plate. The pattern I used has been damaged at the foundry with cracks in the the epoxy pattern. The cracks can be repaired with epoxy and clamped together.
$350.00 ea plus shipping
First pattern
Final design and what I used to make the valve covers
Hairy Olds is offline
Old October 25th, 2012, 02:01 PM
Eightupman's Avatar
Hey, I have a set of those covers... I forgot who made them.
John
Eightupman is offline
BlueCalais79
Hurst/Olds
April 9th, 2015 04:53 AM
jayleo_4
August 26th, 2013 07:01 PM
TripDeuces
January 26th, 2011 05:03 AM
Swede64
December 14th, 2010 05:09 AM
mcutlass1969
April 9th, 2009 10:44 AM
Quick Reply: Oldsmobile Valve cover casting patterns
