Complete 455 built to 1972 W30 Specs GA heads
Old March 20th, 2017, 02:20 PM
airvegas's Avatar
Located just an hour west of Las Vegas, NV is a complete carburetor to pan and fan to flexplate 455 just gone through totally. 030 bore, Forged 2323 Speed Pro pistons, moly rings, New GM connecting rods with ARP bolts, Clevite 77 bearings on a STD/STD Nodular crank, and topped off with redone G heads with large valves. It has a new Melling MT-01 camshaft, Duration 280/290, Lift .448/.472, Melling lifters, stock rockers, new springs, new Cloyes timing chain and gears, Melling M22-HV oil pump and pickup along with hardened steel drive shaft. Also equipped with proper "W" and "Z" exhaust manifolds with stainless steel studs, Engine also comes with a 1972 Automatic trans Quadrajet that has been rebuilt, a 72 GM Distributor, distributor cap, rotor and wire set along with Champion RJ14YC plugs. It has a new fuel pump and water pump, triple pulleys on water pump and crankshaft. Power steering pump mounting bracket, brand new chrome 90 amp alternator and mounting brackets, engine mounts, oil pressure and water temp sensors (for non gauge dash) and an Edelbrock Performer intake manifold. Everything was just assembled with Fel-Pro gaskets, painted in the proper color Eastwood ceramic engine paint and is as complete of an engine as you will probably ever find.
The engine is priced at $3500 with everything you see on it in the photos and everything that's included in the above text.
I do not arrange shipping. I will gladly put the engine on a support stand and bolt it to a pallet for the shipping company you arranged to come pick it up.
To save time, you can email me directly at airvegas@msn.com
airvegas is offline
Old March 20th, 2017, 07:47 PM
vette442's Avatar
Nice piece! Good luck with the sale.
Terry
vette442 is offline
gaerte04
August 18th, 2021 08:22 AM
g356gear
August 1st, 2016 09:35 PM
Stefano
February 10th, 2014 01:42 PM
cdoering
September 25th, 2012 07:17 PM
monzaz
September 5th, 2011 10:45 AM
Quick Reply: Complete 455 built to 1972 W30 Specs GA heads
