Question on Underbody Color on Cutlass / 442 Assembled in Framingham
Old January 7th, 2018, 08:18 AM
Kaline's Avatar
For 1972 vehicles assembled in Framingham, I have the follow questions:
1. Were the underside of the floor pans painted body-color or semi-gloss black?
2. Was the underside of the hood painted body-color or semi-gloss black?
I know from studying an unrestored 1972 Cutlass Supreme assembled in Lansing, both the underbody and the underside of the hood were body color. I am not sure if all the assembly plants followed this strategy. Thanks in advance for your input!
Kaline is offline
Old January 7th, 2018, 10:40 AM
72 Olds CS
RetroRanger's Avatar
My442 worked at the Framingham plant at some point.
My Arlington built 72 was mostly red oxide primer under w body color overspray.
RetroRanger is offline
Old January 7th, 2018, 02:03 PM
My442's Avatar
The bodies (firewall back) with doors and deck lids were dipped in a huge vat of red oxide primer, then sent through an oven to dry. The bodies were then painted.
The bottoms of the cars had overspray on them.
The front clips were painted separately, and them married to the body at the body drop station.
The underside of the hood was painted body color.
My442 is offline
Old January 7th, 2018, 06:03 PM
Kaline's Avatar
Thank you very much!!!
Kaline is offline
Old January 7th, 2018, 07:32 PM
70Post's Avatar
Underside of hoods were black....with some possible body color overspray near the edges.
70Post is offline
Old February 3rd, 2018, 10:40 AM
Miles71's Avatar
My Framingham 1971 CS, all original has Red oxide primer on the underside of the floor pans.
This car only has 36,000 original miles.
Red Oxide, Underside near fuel tank. The whole underside of my 71 CS Framingham car is this red color.
Near Transmission. There is even Red inside the floor support.
Miles71 is offline
Old February 3rd, 2018, 05:47 PM
costpenn's Avatar
Same here - my 71 Supreme had very litlle black on the floor undersides, red oxide is far and away the dominant color. Totally unlike the Lansing cars I have done which are almost all black or body color overspray.
costpenn is offline
Old February 4th, 2018, 05:28 PM
anthonyP's Avatar
Because my brother's Framingham built '71 442 was undercoated by the dealership, always thought the underside of the floor pans were black. So did the Fremont assembly plant, in addition to the Framingham and Arlington plants, also use the red oxide primer? Did Lansing use the red oxide primer, then spray black paint on the underside of the floor pans?
anthonyP is offline
Old February 5th, 2018, 07:11 AM
Miles71's Avatar
My 1970 CS is also a Framingham Mass, car. This car had the underside coated with black stuff, most likely by the dealer. The 70, has 135k miles and more rust. There are some indications it may have been undercoated in red. I will try to check get some pictures soon.
1970 Cutlass Supreme, Built in the town of Framingham Massachusetts.
Miles71 is offline
BAOKBOB
November 23rd, 2017 07:19 AM
442KoneKilr
October 14th, 2015 09:02 AM
costpenn
September 28th, 2015 05:15 PM
allyolds68
August 10th, 2015 05:20 PM
wills30
August 18th, 2014 06:28 PM
Quick Reply: Question on Underbody Color on Cutlass / 442 Assembled in Framingham
