Hood Hinges
Old October 26th, 2018, 11:18 AM
70-455's Avatar
Hood Hinges
What is the factory color for the hood hinges on a 70 442.Black or cast metal color??
70-455 is offline
Old October 26th, 2018, 12:57 PM
My442's Avatar
Neither.
They are gray phosphate.
My442 is offline
Old October 26th, 2018, 02:07 PM
70-455's Avatar
G.m.
thanks.
70-455 is offline
Old October 31st, 2018, 04:05 PM
briane's Avatar
To be precise, manganese phosphate.
briane is offline
Old November 1st, 2018, 07:33 AM
The phosphate is a chemical process, not paint. Here's an article on how to do it.
joe_padavano is online now
Old November 1st, 2018, 09:22 AM
Randy C.
rcorrigan5's Avatar
Just something to think about if you want to go about restoring your hinges a different sort of way. I took the springs off of my hinges and then bead-blasted both hinges and springs. I had a homemade tool that I used to remove the springs and keep them expanded so I could fully bead-blast them. Once blasted and cleaned, I primed them with Zero Rust grey. Then, I painted the hinges cast iron grey and the springs a Seymour paint called stainless steel. They have been on my '68 since 2007 and, although not the original finish, they still look great.
Randy C.
rcorrigan5 is offline
scrappie
June 13th, 2018 03:44 AM
firefighter5174
June 2nd, 2015 08:08 PM
JimMorrisonFan67
April 16th, 2012 07:55 PM
scott strange
February 15th, 2011 06:48 PM
Quick Reply: Hood Hinges
