Acrylic Lacquer over 2K primer ??
Old July 10th, 2020, 05:07 PM
Phantom Phixer
Charlie Jones's Avatar
The guy that's doing my quarter panels wants to use a 2K primer .
I'm going to paint the car with acrylic lacquer . Will this work ?
Charlie Jones is offline
Old July 11th, 2020, 05:30 AM
chopolds's Avatar
In short, yes. No problem at all. As long as the 2K is fully cured.
chopolds is offline
Old July 11th, 2020, 07:18 AM
Phantom Phixer
Thanks . " Fully cured " would be how long ?
Old July 11th, 2020, 07:30 PM
chopolds's Avatar
Honest answer is "it depends". Depends on the type and brand of paint (read your tech sheets). But also depends on temperature, humidity, possibly, and air flow. You have to read the instructions, and compensate for environment.
chopolds is offline
Old July 11th, 2020, 08:27 PM
Phantom Phixer
OK , thanks . I will have to find out what brand of 2K he uses and look up the tech sheet .
The body is on a rotissirie now . and it will be several months before I get the body back on the frame , assemble most of the rest of the car , then paint it .
Old July 13th, 2020, 04:49 AM
chopolds's Avatar
Several months would never be an issue. At most, might have to wait a week. Some primers, overnight.
chopolds is offline
Old July 13th, 2020, 08:08 AM
Phantom Phixer
OK , Thanks .
Old September 8th, 2020, 09:10 AM
Brad J.'s Avatar
Why go through all the labor for a paint job and put garbage on it? We have urethane Clears and Single Stages that are so much better than lacquer. Even an activated enamel is better. I just can't wrap my head around this.
Brad J. is offline
Old September 8th, 2020, 05:25 PM
Phantom Phixer
It's easy , clearcoats peel after 10 years . Well cared for lacquer jobs can last 50 years or more .
And you can't get the look of an acrylic lacquer job with any "modern " paint .
Old September 9th, 2020, 03:26 AM
Brad J.'s Avatar
You sure about that. I own 2 cars painted in the late 80's with lacquer and both started cracking at the 15-20 year mark. I just finished a 53' Buick Skylark that was done in 88' that had to be stripped and redone due to cracking lacquer paint. Also the new lacquer from PPG is absolute garbage as they have taken the lead out. I sprayed some black five years ago on a repair job and had nothing but trouble with it and I learned how to paint with acrylic lacquer. I refuse to use the stuff now as it isn't the same as it once was.
Clearcoats do not peel in 10 years unless their isn't enough mil thickness for the UV protection. This could be a problem with a production shop using cheap clear with 2 coats. You can't do a showcar with 2 coats so that isn't a problem.
Buffed paint is buffed paint. Shiny is shiny. The body on my 31' Buick is black lacquer and I repainted the fenders 10 years ago with base/clear due to cracking. I've asked the know it all's that spout the lacquer bs to tell me what parts of the Buick are done with each. They usually tell me the fenders are lacquer as they look better than the body. I've even used base clear over lacquer in spot/fender jobs on repairs because I had no other option and once the two are buffed it's hard to detect.
Lacquer is a hard, non flexible, easily chipped, and needs a lot more care than Urethane.
Brad J. is offline
Old September 9th, 2020, 05:18 AM
chopolds's Avatar
Lacquer may be a bit more fragile, and gets brittle after time (though if you really take care of it, it doesn't), but it definitely looks better. And looks more original, because it IS. I haven't done a modern lacquer job in over 20 years, but I DID do this black nitrocellulose lacquer job back in the mid 90's. The guy brought it back to me, to do some scallops on it, in 2003 or 4, and it still looked fantastic. Though later I was at his place, and he had moved the car from inside his garage, to a tent, outside. I think the killer was that he also used a car cover on it. It developed lots of tiny bubbles in the paint. Not terribly noticeable, but they were there.
It was shot over House of Kolor KP-2 epoxy primer. The depth of finish of lacquer is much better than any BC/CC, or SS enamel. NOT the shine, clearcoated cars look too shiny, plastic-y shiny. Lacquer has depth, like looking into colored glass.
chopolds is offline
Old September 9th, 2020, 06:26 AM
Brad J.'s Avatar
Shiny wins awards. I don't buy the depth thing.
Brad J. is offline
Old September 9th, 2020, 09:14 AM
Gary
VC455's Avatar
I'm an engineer, I married an artist. I could tell you a lot of stories that would be difficult to wrap your head around. After a while I accepted that people have different experiences and values and there is no logic to it.
The best part is that being exposed to artistic thinking helped me be a more creative engineer.
VC455 is online now
Jamesbo
Paint
June 13th, 2020 09:02 PM
Eddie Hansen
Paint
15
February 11th, 2015 12:40 PM
Daisy Dixie
Body work
January 4th, 2014 03:58 PM
Rickman48
January 28th, 2012 09:47 AM
Ranzan
February 14th, 2010 04:46 AM
Quick Reply: Acrylic Lacquer over 2K primer ??
