choke valve jammed
Old Sep 21, 2007 | 04:08 PM
1973_442's Avatar
choke valve jammed
Hi, i have a holley 4-barrel carb and the choke valve is jammed wide open and the car cant start. anyone have any ideas what could cause this and how to fix it?
Old Sep 21, 2007 | 06:16 PM
If your choke is stuck open and you can't move it with your finger then chances are there is some binding in the choke linkage. If I were you I would just loosen the choke from the side of the carb, shoot the linkage with some carb cleaner and then set the choke. If that doesn't fix it then you might have to take the carb off and check it on the bench to identify exactly what is binding. It shouldn't be that hard. Good luck.
golow1
Feb 20, 2022 08:45 AM
240 Gordy
Oct 11, 2020 10:04 AM
1970_442
Aug 11, 2018 07:50 AM
golow1
Hurst/Olds
Feb 1, 2014 08:45 PM
JRios
Brakes/Hydraulic Systems
Dec 13, 2010 11:13 PM
