Other Oldsmobiles Anything not listed above, such as F-85 (1961-1963), Firenza (1982-1988), Starfire (1961-66 and 1975-80), Omega, etc.
Molding clips for 1961 Starfire
Old May 21st, 2015, 09:52 PM
Skylinerwjmc's Avatar
Does anyone have a source for the snap on clips that screw onto the side of the body on a 61 Starfire for the chrome strip that goes down the side over the aluminum trim? My car had them off already when I purchased the car so I do not have a clue what they look like and the usual suppliers ( Fusick, Restoration Specialties) do not seem to carry anything for the Olds trim.
Skylinerwjmc
Skylinerwjmc is offline
Old May 22nd, 2015, 08:09 AM
Skylinerwjmc
Post a photo of the backside of the trim with a ruler for scale. Typically these pieces of trim used clips that look something like this:
Everybody sells these clips. They are available in a variety of sizes, depending on the width of the trim you are trying to attach.
joe_padavano is offline
Old May 22nd, 2015, 09:39 AM
Oldskeeper's Avatar
PM sent
Oldskeeper is offline
Old May 22nd, 2015, 10:44 AM
Joe, thank you for your reply. I have those clips as wel as similar nylon push in. However the area I am asking about, in the door panel and rear quarter you cannot access the back of the clip to put a nut on it. In those areas the Starfire only shows a screw hole in the gap of the anodized aluminum sideing ( see picture ) and an outline that looks like a rectangular clip was screwed in for the molding to snap over. There are four locations on the door panel for these clips and eight in the quarter panel. The other locations for the molding can use the standard clip you have shown for the 3/4" molding.
Last edited by Skylinerwjmc; May 23rd, 2015 at 08:36 AM. Reason: Address response to Oldskeeper rather than Joe
Old August 18th, 2016, 02:48 PM
Salvagedog70's Avatar
These are from a 1961 Olds Town Sedan that I am in the middle of restoring. Did anyone ever find a source?
Salvagedog70 is offline
Old September 18th, 2016, 11:35 AM
1961 Starfire molding clips
No I did not find anyone who had experience with this piece of molding. I ended up using 3/4" plastic clips from a Pontiac supplier. I believe it was the original parks group that I might of ordered these from. Let me know if you have difficulty finding them and I'll look up the invoice
File Type: jpeg
Old September 18th, 2016, 09:04 PM
Tedd Thompson's Avatar
There are clips that have a push in stud that doesn't need a nut on the back side and will work in a blind hole. Works something like a moly bolt. I found the ones I needed at a fastener store..... Tedd
Tedd Thompson is offline
SwissOldsmobile
July 2nd, 2009 03:00 AM
Willidog
Body work
April 11th, 2009 06:52 AM
Threejdsolds
December 11th, 2008 09:22 PM
tarheeldoc
November 19th, 2007 05:55 PM
jasburns007
January 5th, 2007 01:55 PM
Quick Reply: Molding clips for 1961 Starfire
