How to remove clock handle to change gauge glass
Does anyone know how to remove the clock adjuster handle/**** to change the gauge glass. I bought a 1969 tick tock tach off of E-Bay that I was told had a quartz clock in it. The glass was cracked by the clock adjuster **** and thought no big deal to change. Well I cannot figure out how to remove the **** and I am worried about breaking the clock. I have removed the tach from the metal housing and have removed the clock from the inside of the tach but stil cant remove the adjuster ****. I have pulled up on the **** and held the adjuster stem with a small pair of needle nose vise grips and tried unscrewing the **** by hand, no luck. Do I need to put pliers on the **** while holding the adjuster stem to unscrew it? I am very worried about breaking the clock but I want a nice close fit on the new glass to keep dust out of the gauge face. Any help would be greatly appreciated. .....Todd
Thanks guys it was indeed threaded on as I thought but was worried about breakig it. i was told to soak the back side of it with some WD40 which I need and left it for a couple of hours. I pulled up on the **** and held it there with a small pair of needle nose vise grips, i then put some electrical tape on the **** as to not damage it as I put another small pair of regular vise grip on the ****. It came free relatively easily this time and I'm good togo. got the new glass in and it looks great! Thanks for your help! Todd
KRICHEN922
July 1st, 2010 09:17 AM
