Other Oldsmobiles Anything not listed above, such as F-85 (1961-1963), Firenza (1982-1988), Starfire (1961-66 and 1975-80), Omega, etc.
62 starfire heater valve and mounting bracket
Old May 3rd, 2015, 12:44 AM
viper771's Avatar
I have a question for you guys. Been working on the 62 again and I am putting a new intake gasket on. I noticed the heater valve was replaced (I will take a pict tomorrow) but I wanted to ask, which would be the correct substitute for the heater valve? I guess they are hard to find or they don't repop them.
Also, I noticed that the plate it screws into on the block is kind of messed up. The threads in the actual plate on one side are totally worn out and the screw won't screw into the plate on that side (just slides into the hole) but the other side still has threads. Now does anyone know where to find another plate, or will it be ok to just use it as it is, since the screw just goes down into the block anyway. I didn't see it leaking or anything but it may not have sealed properly (previous owner put RTV under the intake gasket, which got hard and started to leak all over the place).
Anyone else run into this problem? I suspect that someone in the past just over tightened that side and stripped the threads out Thanks in advance!
viper771 is offline
Old May 3rd, 2015, 07:34 AM
Oldskeeper's Avatar
Hi Martin, the plate has a pipe thread in the middle hole and it will be stamped top on one side, the other holes are not threaded as they are clearance holes for the bolts into the head.
This valve was repoped for a while and every once in a while one shows up on e-bay.
Steve
Oldskeeper is offline
Old May 3rd, 2015, 02:43 PM
viper771's Avatar
Thanks for the info steve! I have no idea what an original is supposed to look like but I will keep my eyes open. I guess I don't have to worry about the threads being messed up in the clearance holes if they aren't supposed to be threaded anyway. Thanks again! I hope to get the intake back on her soon
viper771 is offline
Old May 3rd, 2015, 04:21 PM
Oldskeeper's Avatar
I'll get a pic off to you from my car, I replaced mine last week.
Old May 4th, 2015, 06:09 PM
1962olds's Avatar
Hot water valve
usa parts supply lists one on page 30 in there online catalog. $99.95.
part no. S9.795H, if you cannot find it elsewhere. Here is one on EBay http://www.ebay.com/itm/NOS-Olds-Ods...a979cd&vxp=mtr
1962olds is offline
Old May 4th, 2015, 10:20 PM
viper771's Avatar
Oh wow that looks totally different than what I have on my car now. Mine looks more like this
http://www.ebay.com/itm/Four-Seasons...1828c3&vxp=mtr
I guess they should both work the same? I believe the USA parts supply one looks like this too. Very cool to see an NOS one!!! Thanks! That is new to me!
viper771 is offline
Old May 5th, 2015, 05:52 PM
1962olds's Avatar
My guess is either one should work fine.
1962olds is offline
Old May 7th, 2015, 11:08 PM
viper771's Avatar
Ok that is also good to know Thanks!!!
viper771 is offline
OLDSmobility
Brakes/Hydraulic Systems
April 29th, 2011 08:15 AM
19Starfire62
April 18th, 2011 03:34 PM
19Starfire62
October 15th, 2009 02:45 PM
Quick Reply: 62 starfire heater valve and mounting bracket
