Fuel hose identification
Filled up and when I got home I smelled gas. Found this hose leaking. 1 hr later, it's still dripping. Where does it go? It's the one below the vent tube on the passenger side. Looks like it is either really swollen or has a cover around it so it doesn't rub through...
Thanks in advance!
That hose leads to the tank vent that can be seen in the clamp above it. Time to replace both the vent hose and the supply hose. Hoses will be 5/16” or 3/8”, not sure which. Pretty simple job, probably a good idea to run the fuel level down a bit before doing the deed.
Looks like a vapor canister line may have been abandoned.
