Evaporator Core
Old April 22nd, 2014, 06:24 PM
501Paratrooper's Avatar
Evaporator Core
I've got my A/C box off and was going to refresh it up, I noticed that it has an original Harrison 3014078 SAE-AIR-60 Evap Core.
The core looked good, no corrosion, apparent leaks and worked fine before dismantiling the car. Should I have this one tested/repaired or get a new one?
Also since the box is off any reccomendations on the other stuff to replace. I see Classic Auto Air has a resto service for these @450.00 per.
If I replaced the parts individually would this be a deal?
Thanks gentlemen.
501Paratrooper is offline
Old April 22nd, 2014, 06:38 PM
Macadoo's Avatar
This thread has some really good info on AC service;
https://classicoldsmobile.com/forums...oration-3.html
I just had my evap tested and it tested good. I've heard many do not so it's worth a test before replacing. Are you wanting to convert to 134a or stick with R12? That can make a big difference in your approach.
Here's what I'm doing:
1. Flush evaporator and condenser
2. Replace the reciever/dryer and expansion valve
3. Replace all O-rings
4. Mount the box with new seals and hook it all up.
5. Vacuum and charge with R12 and call it a day.
Macadoo is offline
Old April 22nd, 2014, 06:47 PM
I'll probably convert it to 134a.
Old April 22nd, 2014, 07:30 PM
Lady72nRob71's Avatar
I would have the core cleaned, pressure tested, and and if good, flushed. Then you can reassemble and use the refrigerant of your choice. The evap and exp valve work for either type. Your POA will need to be adjusted for R134, dryer replaced, and the rest of the system flushed. MAW test the condenser and paint it up too. If you plan on using your original compressor, it will need to be drained of oil and possibly flushed out also. I am not even sure it it can be flushed. The original oil in the R12 system is not compatible with 134.
You said the evap worked fine so if the whole AC system is working, I would just recharge it with R12 like Mac mentioned above.
Lady72nRob71 is offline
Old April 22nd, 2014, 07:55 PM
Thanks, So many MAW's! I'll replace the blower motor just for peace of mind, it looks original. I just saw that I have a blower resistor that is pretty scarce, hopefully mine will hold out. The box should clean up nice.
Old April 23rd, 2014, 06:16 PM
And while pulling that resistor, MAW check the contacts and connector for burning or pitting. Rockauto has the connectors if yours was shot like mine was.
Old April 23rd, 2014, 06:26 PM
Thanks Rob, btw did your famous RP upgrade, worked perfect thank you.
westside807
April 21st, 2014 02:20 PM
1arunem
September 3rd, 2013 07:32 PM
Lady72nRob71
July 30th, 2011 08:14 PM
KZ442
November 11th, 2009 08:25 AM
jeffs 89 cutlass salon
October 22nd, 2007 12:46 PM
Quick Reply: Evaporator Core
