Conv top issue - 72 Cutlass
Old March 27th, 2023, 11:13 AM
NorthBay72supreme's Avatar
I recently picked up and installed a new top motor and fluid lines. When I ran it for the first time, the motor was straining and I saw lots of air in the lines. I went through the instructions on the motor, adding ATF and not exceeding 75% capacity, then running the top with the hydraulic cylinders disconnected from the top. I'm not sure how a person can tell if it or over 75% capacity. The fill plug is about 3/4 of the way up from the bottom, so I added fluid until it barely started to drip out of the fill plug.
After going through this cycle a few times, air in the lines was gone. Grabbed a bite to eat and came back to the car to reassemble. Connected the cylinders back to the top, and the very first time I ran the top, fluid shot out of the top of the cylinder on the passenger side only. Fluid escaped the cylinder toward the top where the rubber seal is.
Do I have a bad cylinder if it's just the one that had this issue? Or did I overfill the pump motor? I'm not sure of a testing procedure for this. My bet is that the cylinders are original. Maybe it's time to replace both after 71 years, but I don't want to do that if overfilling the pump motor was the issue all along. If that is the case, I'll just destroy the new ones.
NorthBay72supreme is offline
Old March 27th, 2023, 12:23 PM
I recall reading where someone else had a similar issue related to overfilling the system.
That math doesn't seem right.
Fun71 is offline
Old March 27th, 2023, 12:39 PM
LOL the 5 and 7 key are close and my fingers are fat!
Old March 27th, 2023, 01:44 PM
I recall reading one or more cylinder top threads/posts, as well. I'm keen to recall those threads/posts since I have a '71 CS convertible and I try to keep up on things when I read of items pertinent to my car. Here is a list of "top cylinder" threads/posts. It may change. If it does, perform a search with the keywords "top cylinder" (quotes must be included). You'll need to read and decipher if any of these threads/posts are pertinent to your issue - I can't assist there. Good Luck!
https://classicoldsmobile.com/forums...archid=6717674
Vintage Chief is offline
Old March 27th, 2023, 06:52 PM
PatL's Avatar
Guys, forgive me, I just don't see how "an overfilled pump reservoir" would cause leaking out of the top of the hydraulic cylinder. Say the OP missed the mark at 75 % and hit at 90% how would the cylinder now leak. At leak at the pump seems more feasible if it is overfilled.
PatL is offline
Old March 27th, 2023, 07:00 PM
Yeah that makes more sense. I think the issue in the post I was remembering is the pump reservoir was topped off when the pistons were extended so it overflowed when they were retracted.
Fun71 is offline
Old March 27th, 2023, 07:49 PM
bccan's Avatar
I always filled pumps til it dribbled out the hole and never had a problem. Causing a cylinder leak? Can’t imagine it.
bccan is offline
aslockcuff
March 28th, 2023 07:11 PM
kens69olds
August 24th, 2014 03:51 PM
Jimmy C
June 29th, 2013 11:06 PM
bigfun64mo
March 22nd, 2010 08:47 PM
ELECMAN
March 9th, 2010 09:16 AM
Quick Reply: Conv top issue - 72 Cutlass
