Column shifter
Column shifter
Recently bought a beautiful billet shifter which ended up not fitting. Universal fit my ***.
Now I can’t get the OE shifter back in. I can partially insert it and shift from park to R to neutral, but that all done with the pin installed that holds the shifter in place. SOS
so to reaffirm - you can currently shift the column from Park thru neutral with the factory lever fully reinstalled but not into drive? or are you saying the lever won't go fully back in to where you can reinsert the pin?
Is that a factory tilt or non-tilt column? I'm assuming non-tilt because you have a non-tilt shift lever (the tilt lever is not as long at the end and squared off at the tip, no point - they're not interchangeable but you can easily grind the point off to where it will work on a tilt-column.
