Bringing AC back to life
I have a 72 Cutlass....it's an AC car but hasn't worked in the 3 years I've owned her. The wiring harness on the compressor is missing 2 of 3 wires. I know I need to replace that. And more.
I have the shop manuals, assembly manual, and the Fisher body manual. Searched through them and couldn't find a good diagram of the AC system at large. Aside from needing to replace the harness, I don't have any relays. Not sure what's required on that front. Hoping someone can direct me to a good source of info or provide it here.
Also and as an FYI in the event it's relevant, the heater works great.
Thanks guys.
Thanks guys.
If #s matching not a thing for you, and assuming your a/c may need a significant overhaul anyway, might want to contemplate a Vintage Air system install - bonus is it eliminates the under-hood evaporator core assembly from the mix, which opens the entire right side of the engine bay up for motor access . More efficient/smaller compressor and all electronic heating and air (no mechanical cables, vacuum requirements for actuators or main switch, etc) - did that to my car about 4-5 years ago and haven't looked back.
