Non-Olds Engines For discussion on non-Oldsmobile engines. All forum rules apply.
1964 Cutlass F85 with Chevy 350 Engine
Old April 30th, 2007, 07:28 PM
hardrider442's Avatar
Question 1964 Cutlass F85 with Chevy 350 Engine
hi! I have a 64 cutlass f85 2 dr that came with a v8 330 engine, now a to put a 95 chevy 350 engine , so i brought 64 chevelle motor mounts , but it didntfit motor mounts on chevy engine are in front of block instead of in middle like in olds engine, what can i do? i have to move the engine back like 6 inches or more do i have to fabricate mouting plates to the chassis? or change the motor mounts on engine? help will be appreciated
hardrider442 is offline
Old May 1st, 2007, 12:15 PM
2Blue 55
American Lead's Avatar
I am told if you switch from an olds to a chevy engine, you have to do somr fab work on the mounts. There are a few posts floating around. Keep me posted if you find anything.
American Lead is offline
Old May 1st, 2007, 01:48 PM
Considering that the Chevelle and Cutlass use the same frame, that's obviously not true. The problem is that you have an LT1 motor instead of a more traditional SBC. Pretty sure LT1 blocks have different mount locations. Sell the Chubby, get an Olds 455, and it's a bolt-in.
joe_padavano is offline
Old May 1st, 2007, 03:59 PM
no, my sbc has same mountings as early sbc its not an lt1 , but the mods has the be done to the frame or to the block mounts?
Old May 1st, 2007, 04:00 PM
help me I didnt find nothing
Old May 1st, 2007, 04:58 PM
Look, you could get an SBC in a 64 Chevelle and that's the same frame in your Cutlass. Just get the motor and frame mounts for the Chevelle. The bolt holes are already in the crossmember. There's no "fabrication" necessary.
Old May 2nd, 2007, 04:33 PM
2Blue 55
If you click the search button underneath the main tool bar and type in engine swap or somthing there ar quite a few posts you can scroll through and read. I will ask a few people and send a few e-mails and see what I can come up with. Let me know if you have any luck
I will try to get back to you withen the next week.
Old September 28th, 2014, 08:51 PM
ewindgale's Avatar
I also have '64 Cutlass with 330 engine which I want to replace with LT-1 engine. The motor mount locations are different. Are there mount conversions available?
ewindgale is offline
Old September 29th, 2014, 06:26 AM
As stated, the Cutlass and the Chevelle are basically the same, you need to treat it as a Chevelle. So either you need to purchase or fab frame brackets for the LT1 motor mounts. Heres a helpful site to join:
http://www.chevelles.com/forums/
oldcutlass is online now
Old September 29th, 2014, 09:28 AM
Octania's Avatar
Whatever happened to the time honored method of dropping the engine in, see where the things need to be, tack weld 'em in place, remove engine, weld mount tabs to frame... if no holes exist handy already. Just do it. Fab your own stuff as needed. Cut, grind, hammer, bend, weld.
Octania is offline
Old October 9th, 2014, 03:45 PM
64Rocket's Avatar
I say sell the Olds and buy a chevelle. problem solved.
Why down grade the Olds.
Gene
64Rocket is offline
moys71
February 16th, 2021 08:22 PM
Jolds86
December 16th, 2014 07:49 AM
64oldsf85cutlass
Body work
July 4th, 2014 07:06 AM
65442ragtop
May 21st, 2014 10:59 PM
billmerbach
October 17th, 2013 11:10 AM
Quick Reply: 1964 Cutlass F85 with Chevy 350 Engine
