Non-Olds Engines For discussion on non-Oldsmobile engines. All forum rules apply.
Mopar ignition coil gets very hot
Old June 21st, 2016, 09:31 AM
Octania's Avatar
Interesting. Working on SOB recently, 71 440 Challenger, I noticed that the coil was EXCEEDINGLY hot, like way too hot to touch. Guessing 140F or more. Seems wrong to me. What say ye?
Stock 1971 electronic distributor, box on firewall, resistor on firewall. Coil is new and presumably came with the now unused LameThrower [sic] distributor.
Also, why would it have THREE wires on the coil (-) before we even put the tach wire on?
Octania is offline
Old June 21st, 2016, 10:27 AM
I moved your unrelated post so as not to confuse the op. I don't know why your coil is getting that hot, the wiring should look like this:
oldcutlass is online now
Old June 22nd, 2016, 10:01 PM
same but different
don71's Avatar
Just happened upon this comment about hot coils...FYI please read post #7
http://forums.maxperformanceinc.com/...d.php?t=791842
don71 is offline
Old June 23rd, 2016, 06:07 AM
There are major differences between a Mopar setup and stock/aftermarket Gm systems. Mopar basically uses 3 different ignition control boxes, 1 being strictly for racing. On all 3 the coil is triggered through the box and not the distributor. My guess would be a faulty box or ballast resistor and/or power wired wrong. They are an easy system to setup, but more difficult to trouble shoot.
droldsmorland
May 3rd, 2015 07:43 PM
Eddie Hansen
Paint
15
June 12th, 2012 06:13 AM
9drsixwheelolds
November 1st, 2010 09:15 AM
lshlsh2
May 26th, 2009 07:05 PM
blunce
August 5th, 2008 10:56 PM
Quick Reply: Mopar ignition coil gets very hot
