Non-Olds Engines For discussion on non-Oldsmobile engines. All forum rules apply.
questionbout 88 camaro
Old January 30th, 2013, 07:25 PM
1970 olds cutlass supreme
rocket350's Avatar
if i drive through a puddle, the steering will lock up andwill only turn a little bit.
it returns to normal after about a minute.
whatcan be causing the lockup
rocket350 is offline
Old January 30th, 2013, 07:37 PM
lemoldsnut's Avatar
steering gear lock up
Is it in a puddle or just when it gets into a bind? Like hitting a bump or pot hole? Could be the control valve at the top of the steering gear. They have seals that seperate the ports in it. If they are worn it can flow to two directions at the same time. "locking up" There is a check valve in the back of the pump that could be weak too. But, more than likely is the gear valve. Meaning replace the gear.
Hope that helps
Larry
lemoldsnut is offline
Old January 30th, 2013, 08:00 PM
rocket350's Avatar
Hope that helps
Larry
its only when i go through puddles
Old January 30th, 2013, 08:18 PM
Your power steering belt is loose.
Puddle splashes water onto belt.
Belt slips.
Steering gets tight.
If you do some serious barbell work, you'll stop noticing it when it happens.
MDchanic is offline
Old January 30th, 2013, 08:27 PM
Rickman48's Avatar
Replace the belt.
Rickman48 is offline
Old January 30th, 2013, 09:42 PM
rocket350's Avatar
Originally Posted by Rickman48
Replace the belt.
ok ill look into replacing the belt, too lazy to do barbell work lol
TOONLOVESCHERYL
February 17th, 2010 11:40 AM
Topless72
March 19th, 2008 03:29 AM
tex70
January 27th, 2007 08:31 PM
mjscutlass
December 26th, 2006 07:12 PM
Winnipeg Cutlass
April 17th, 2006 03:15 PM
Quick Reply: questionbout 88 camaro
