Non-Olds Engines For discussion on non-Oldsmobile engines. All forum rules apply.
66 Cutlass 6.0LS
Old June 28th, 2019, 09:08 PM
  #41
Thanks for the update
oldcutlass is online now
Old July 23rd, 2019, 07:18 PM
  #42
Justin
oldstata's Avatar
Very nice and clean Build, do you know the part number on the headers you used ? And did they have any clearance issues around the trans or steering arm ?
oldstata is offline
Old July 23rd, 2019, 07:47 PM
  #43
mike1976's Avatar
I used the hooker exhaust manifolds and there are not any clearance issues. Here is a link for the Holley website, https://www.holley.com/products/ls_p.../parts/8502HKR
mike1976 is offline
Old July 25th, 2019, 07:35 AM
  #44
mike1976's Avatar
After driving the car quite a bit this summer I have noticed that the aftermarket gas pedal was coming loose. I have tightened the bolts but I am also considering tacking it in place with a couple spot welds. Any thoughts on if I should do this so the problem does not persist?
Mike
mike1976 is offline
Old July 25th, 2019, 08:15 AM
  #45
Justin
oldstata's Avatar
Mike
Any pics of your gas peddle? I am interested in how it’s mounted
oldstata is offline
Old July 25th, 2019, 05:11 PM
  #46
mike1976's Avatar
There are two bolts coming through from the other side of the firewall that hold the gas pedal in place.
mike1976 is offline
Old July 25th, 2019, 05:50 PM
  #47
harleyrules's Avatar
Did you use locktite on the bolts?
harleyrules is offline
Old July 25th, 2019, 08:02 PM
  #48
Justin
oldstata's Avatar
Dontou know what part number the peddle assembly is by chance or was it a gm one from a donor car
oldstata is offline
Old August 3rd, 2019, 08:44 AM
  #49
mike1976's Avatar
The pedal is now mounted with a couple of washers and loctite on the nuts. It now feels very firm and is much more responsive than it was before. It is a lokar gas pedal.
mike1976 is offline
Old August 4th, 2019, 03:12 PM
  #50
RonFX's Avatar
Great Build, I have the same 66 Cutlass w/ a BBC in it as well.
RonFX is offline
BOOWAH
July 5th, 2019 10:34 AM
ctosiflying
March 7th, 2019 07:53 PM
Rodolfo Elias
January 19th, 2019 05:53 AM
agtw31
August 31st, 2010 09:32 AM
Quick Reply: 66 Cutlass 6.0LS
