Non-Olds Engines For discussion on non-Oldsmobile engines. All forum rules apply.
6.0l lq4
Old March 18th, 2018, 01:13 PM
Andrew83's Avatar
6.0l lq4
Hello olds heads. This upcoming Friday I'm pulling the trigger on a 6.0L LQ4 build from block to turn key.
This engine Ine is going to be going into my 73 Cutlass "S" optioned 442.
I know these engines have been used in earlier model cutlasses and there is modification/aftermarket parts needed for fitment. Which I'm prepared to do to make work.
Im having a hard time finding any 73's out there with these engines in them. My question is is this that much different of a logistical fitment issue then earlier model cutlasses? The last thing I want to do is pay for this build and for whatever reason find out it "can't work".
If anyone hasexperience or knowledge about this swap it would be greatly appreciated. I know that holley makes a retro aftermarket oil pan that will be needed. And I also know the wiring harness will have to be modified. Other than that I'm all ears. Thanks everyone
Andrew83 is offline
Old March 19th, 2018, 09:39 AM
brownbomber77's Avatar
The GMPP pan should work. It's half the cost and just hangs a little bit lower. Otherwise, logistically, it should fit in the same as the earlier models. Consider headers for these cars are typically model years 68-77 if that says anything about the front frame. Check out G3GM.com. There's a couple guys who have done this already in their 73-77 A bodies.
brownbomber77 is offline
Old March 19th, 2018, 10:22 AM
csouth's Avatar
BRP Musclerods has mounts and headers for this body style. GMPP or Holly pan would work. Holley is more expensive ..
csouth is offline
Old March 20th, 2018, 04:58 AM
Andrew83's Avatar
Alright perfect thank you guys for the direction greatly apriciated.
Andrew83 is offline
Old March 21st, 2018, 07:19 AM
ach1992880's Avatar
i have to disagree about the GMPP pan, and doubly so if you ever plan to lower your car. The pan hangs below your engine crossmember making a fragile bit of aluminum your first point of impact if you should ever bottom out. I know the holley pan is pricey but the 302-2 or 302-3 are the only way i would go. Mounts shouldnt be a problem, and as far as exhaust fitment i would recommend searching ls1tech.com for anyone else running a '73-up A body to gain some knowledge from. Best of luck with the build you'll love the results.
ach1992880 is offline
Old March 21st, 2018, 11:48 AM
csouth's Avatar
When you are referencing pan to crossmember clearance, the GMPP pan will work. If you are asking "is it the best pan out there for the swap?", no. I personally would not use the Holley pan either. IMO the best pan out there is the Speedtech performance pan with provides crossmember clearance, does not hang low, has a built in baffle and has fittings for remote oil filter and\or oil cooler. Now you're talking about a $700 pan though.
csouth is offline
DewChugr
Non-Olds Engines
January 12th, 2015 09:48 AM
Quick Reply: 6.0l lq4
