Help 74' 98 No turn signals.
Old January 30th, 2008, 02:58 PM
h4l420's Avatar
The bar for the turn signals is completely loose and it wont work for turning or cruise control (which I could careless about)
How do I fix this?
h4l420 is offline
Old January 30th, 2008, 06:12 PM
Modern Motoring's Avatar
sounds like you need to pull the steering wheel and find out whats broken. Good news is, every thing you need to repair it is available at your local parts store.
Modern Motoring is offline
Old January 30th, 2008, 06:32 PM
Seasoned beater pilot.
J-(Chicago)'s Avatar
Is the signal lever attached to the column.....
or hanging by the cruise wire?
J-(Chicago) is offline
Old January 31st, 2008, 10:02 AM
Oldsdruid
rocketraider's Avatar
Is the car tilt, tilt-telescopic, or non-tilt? all attach to the t/s actuator differently. Tilt and non-tilt attach to actuator with a screw and you have to pull the steering wheel and lock plate to get to it. Tilt/tele screws into the actuator.
rocketraider is online now
Old January 31st, 2008, 10:30 PM
h4l420's Avatar
Ok thanks guys I think I got it just got to take apart the steering colum
h4l420 is offline
projectheaven
August 17th, 2008 08:58 PM
palmers65
May 30th, 2008 11:12 AM
cola
March 21st, 2008 03:44 PM
wizzy01
November 20th, 2007 04:03 AM
falconsfan
March 19th, 2007 04:58 PM
Quick Reply: Help 74' 98 No turn signals.
