Brake Cable Location
Old March 20th, 2014, 11:07 AM
m371961's Avatar
What is the correct location for the emergency brake cable. Mine is on top of exhaust, below trans and trans crossmember. In the only drawing I found it appears to be between floor and crossmember and on top of transmission.
Seems it would rattle on top of exhaust pipes.
m371961 is offline
Old March 20th, 2014, 11:17 AM
m371961's Avatar
Sorry, 65 - 98
m371961 is offline
Old March 22nd, 2014, 12:02 PM
m371961's Avatar
Laying on my back, I am guessing the cable should run across the top of the crossmember and cross under the trans.
m371961 is offline
Old March 22nd, 2014, 12:23 PM
Have you checked your Chassis Service Manual?
MDchanic is offline
Old March 22nd, 2014, 12:30 PM
m371961's Avatar
Yea Eric, thats the only drawing I found. Mine has always been below the crossmember and trans, so I thought I would ask. Just looking at it, crossing over the top of the trans doesn't look correct, but if the CSM is correct, it must be how it is.
m371961 is offline
Old March 22nd, 2014, 12:41 PM
To me, that illustration shows the cable passing above the crossmember, but below the transmission, just like you said.
To my eyes at least, the portion of the cable passing under the transmission is slightly greyed-out in the picture, indicating that it's on the other side of the transmission.
MDchanic is offline
Old March 22nd, 2014, 12:45 PM
Here's a super close-up of my electronic version.
Looks like it passes underneath to me.
MDchanic is offline
Old March 22nd, 2014, 04:35 PM
m371961's Avatar
Thanks MD, Now I see, (said the blind man). I am more used to prints where it would be a dotted line. Guess I need to look closer.
m371961 is offline
Old March 22nd, 2014, 04:54 PM
You're welcome. Having a second set of eyes look something over is always helpful.
MDchanic is offline
defiant1
February 4th, 2020 08:53 PM
rootney
June 27th, 2014 11:30 AM
dmberendsen
April 10th, 2013 03:18 PM
macvic
Brakes/Hydraulic Systems
August 2nd, 2007 12:18 PM
bigbrother
June 18th, 2007 12:34 PM
Quick Reply: Brake Cable Location
