1959 Speedometer accuracy
Old November 9th, 2019, 08:35 AM
gkhashem's Avatar
The drum appears to work fine but as you go to higher speeds it becomes inaccurate.
So at 40 MPH, the drum may say I am going 43 MPH, but at 65 MPH, the drum says I am going 80 MPH.
Is this just the nature of the beast due to age or what? No shimmies, strange movement all is smooth.
gkhashem is offline
Old November 9th, 2019, 03:17 PM
I don't know for certain this is your issue, but that is essentially what happens when the tire height or rear gear ratio are changed from the factory setup. The speedometer calibration will be off by some percentage, so it will read correctly at 0 MPH and as speed increases the MPH offset becomes larger. With shorter tires / lower gears the indicated MPH gets larger than the actual MPH; with taller tires / higher gear ratio the indicated MPH gets less than the actual MPH.
Fun71 is offline
Old November 9th, 2019, 05:13 PM
gkhashem's Avatar
Thanks for the suggestion, I should have stated the car does have new Coker bias tires that are the correct factory size. So that should not be the issue and what was on the car when I got it was the same tires.
So that should not be the issue.
gkhashem is offline
Old November 10th, 2019, 08:43 AM
I think the speedo is run by a magnetic force from spinning, against a spring. Slower and jumpy means badly lubed cable or a hang up. Too fast, I presume, is a weak spring.
Koda is online now
Old November 10th, 2019, 11:31 AM
gkhashem's Avatar
No bumpy movement, so it must be a weak spring. Can you replace the spring or get a NOS drum?
I will probably leave it but curious.
gkhashem is offline
Old November 10th, 2019, 05:17 PM
Phantom Phixer
Charlie Jones's Avatar
Hemmings Motor News lists several speedometer repair shops who can check and repair your speedometer .
https://www.hemmings.com/classifieds...et=Instruments
Speedometer repair and calibration is not a DIY proposition .
Charlie Jones is online now
Phoenix8990
Drivetrain/Differentials
March 29th, 2019 07:21 AM
SHJohnson
April 17th, 2014 11:15 AM
Gary's 2 442-S
October 2nd, 2013 07:10 PM
pcard
July 30th, 2013 07:31 AM
art72
July 1st, 2013 07:44 AM
Quick Reply: 1959 Speedometer accuracy
