Newbey from New Jersey - 80 Cutlass
Old November 17th, 2013, 01:23 PM
OldManTucker's Avatar
Hello all, I am brand new to this site and brand new to the world of auto mechanics...never owned a tool so I am learning as I go.
My latest endeavor was to clean out the vapor canister. I've been looking for a vacuum leak for about two weeks and really could find where it is exactly. Somehow I wound up having concerns over the canister and decided that this was an easy job to tackle.
1) Remove canister from the car
2) Break it open from the bottom carefully so you can put it back together (they don't make new ones)
3) Pour out the carbon onto a metal tray and burn off the gas vapors - you can start a huge fire this way - I almost did - so using a small torch just flame up about a cup of the stuff at a time to control the fire remember to NOT COOK THE CARBON. You need to stir it around and add a little flame as you go...eventually all of the gas will burn off and you wind up with fresh carbon to put back into the canister.
4) Replace with all new filter material as required.
I am really glad I did this. The carbon was saturated and the filter material inside was totally clogged up; essentially it was not working. The Service Manual that I have has some nice detailed information on it to help me understand what I trying to do.
Success!
OldManTucker is offline
Old November 17th, 2013, 04:51 PM
Welcome, there are all skill levels on here. Post some pictures when you get a chance.
oldcutlass is offline
Old November 17th, 2013, 08:01 PM
GM Enthusiast
OLD SKL 69's Avatar
Welcome to CO. Glad you were able to fix your problem. x2 on posting pics!
OLD SKL 69 is offline
Old November 29th, 2013, 09:20 PM
Pictures
Thanks for the thought on taking photos. I will do a better job of documenting my work as I realize that one day someone might be in need of the exact same repair/maintenance on their car.
As described above, the canister and coal was recycled and after cleanly breaking it open I figured I would use wire ties to close it back up. Hopefully my photo of the bottom (before the lower filter goes in) will show up. Im still learning how to use this site.
The stalling problem I was having went away after cleaning out this canister.
nine8
July 31st, 2013 08:02 PM
Eddie Hansen
January 23rd, 2009 12:58 PM
bigoldscruiser
December 23rd, 2008 02:33 PM
Pfiffle
July 29th, 2007 08:49 PM
Quick Reply: Newbey from New Jersey - 80 Cutlass
