New Guy AAM - 56 Olds 88
Hello everyone.....I'm new to the site. I have a 56 Olds 88. I've owned the car for about four years and it's in great condition. When I purchased the car, the previous owner said that the engine had been rebuilt. Everything is original, with the exception of the wheels. The car is running great right now, but I've had a few problems within the past year.
In February of 2011, I had to have a new cam and lifters installed. The car ran great up until March of this year. I had another problem with the cam. I had only driven the car 1700 miles! When I took the car back to the shop, they supposedly determined that there was excessive pressure in the valve springs due to incorrect shims? I've gotten feedback from a different site that the problem could be oil related.
Well anyway, I thought it would be a good idea for me to learn and interact with people that feel the same way I feel about classic cars. I'm not a mechanic, so I hope I don't offend anyone by asking dumb questions. I look forward to any feedback.
AAM, 56's had a problem with their cams being soft but after a rebuild and replacement of that cam and another I also would suspect an oil problem or the lack of a zinc additive during the brake in period to be more precise. Most modern oils do not contain enough zinc (ZDDP) to keep the cam and lifters from going flat. This additive was greatly reduced in modern oils because of the problems it gave catalytic converters our older engines suffer because if this reduction. Some racing and diesel oils still contain zinc and if you do a search on this site you will find out more than you need to know on this subject I add a pint of additive with ZDDP in every oil change and have no cam/ lifter problems........Lost in the fifties Tedd
I also would suspect the lack of a zinc additive during the brake in period to be more precise. Most modern oils do not contain enough zinc (ZDDP) to keep the cam and lifters from going flat. This additive was greatly reduced in modern oils because of the problems it gave catalytic converters our older engines suffer because if this reduction. Some racing and diesel oils still contain zinc and if you do a search on this site you will find out more than you need to know on this subject.
http://www.scribd.com/people/view/7936333-dave
Thanks for the good information, I'll pass this on to my repair shop. Is there a certain brand of oil that I can purchase that has the required amount of zinc included?
I was at Pep Boys last week and I saw the zinc additive ( it was in a clear bottle) but I didn't see a certain brand of oil that had the higher level of zinc included. Thanks
Olds 88 Rocket
Vista Cruiser & Wagons
27
June 12th, 2012 06:03 AM
70olds455
September 11th, 2011 03:52 AM
