I have got it bad
I have got it bad
Hi guys here is my list of Olds I have owned.
1955 88 4dr (currently own)
1963 f-85 2dr
1966 cutlass 2dr
1966 cutlass 2dr
1971 cutlass 4dr that was used as parts car
1972 cutlass 2dr notch back
1977 cutlass 2dr 403ci
1978 cutlass 2dr used for parts
1978 cutlass 2dr
1979 cutlass 2dr THE ONE THAT STARTED THE MADNESS!!!!!!!!!!!
1980 cutlass 2dr
1986 cutlass 2dr
1987 cutlass 2dr
1988 cutlass 2dr RWD model
1990 Quad 442
1991 Quad 442
1992 cutlass convertible 3.1l
1993 cutlass convertible 3.4dohc (currently own)
1963 f-85 2dr
1966 cutlass 2dr
1966 cutlass 2dr
1978 cutlass 2dr
1980 cutlass 2dr
1986 cutlass 2dr
1987 cutlass 2dr
1990 Quad 442
1991 Quad 442
Hi welcome the site. Yes you have had a lot of Olds. You'll fit in just fine. If you have any pics that would be great, we like visual aids.
Welcome to CO. We had a thread where people listed their previous Oldsmobiles, I stopped reading it because it got so long, lots of members with a huge list like yours here so you should feel at home here.
I have an issuse with my 55. I have a rear wheel cylinder leaking but I can't fine any one with a wheel cylinder that will except a 1/4" line. Any other cars out there I can get a cylinder that will work? the ones I came accross take a smaller line.
doc93, if there's a casting number on your wheel cylinder would you please post it? I have a couple boxes full of NOS brake parts from the 1930's through the 50's. Some I've keyed out and others I don't know the applications.
John
John
OK guys I am in need of direction. I have finally got the brakes taken care of but I was reading some other threads and looking for a inexpensive front drum to disc conversion. It is for a 1955 88 with manual brakes. Any ideas would be help full.
Impressive list , I am just trying to get my feet wet
Hey Doc ,
I am just trying to find a resonably priced 1991-1995 cutlass convertible , preferably with the 3.1 engine . Please keep me in mind if you see or hear of one . Thanks Chris 248-636-5997
disk brake setup
Doc 93
ScareBird classic Brakes makes a conversion for a 55 but you may have to install a power brake master and booster.I've never seen a disk brake setup that didn't use a power master cylinder and booster.Also Mike Pelenton in Gardnervill or Mendon NV. sells a kit but I couldn't find his number or web site,someone might be able to help you out with that one.....Lost in the fifties ...Tedd
