Engine number
Engine number
Hi, i am from Australia and i have added a 71 Cutlass Supreme to the family. There are not to many Cutlass 's down under .
It was imported by the guy who moved here,I have started a frame off resto
and already found this site a great place to find information
and was wondering if anyone could ID my Engine Number it is 47X140098 .
Will post photo's as the rebuild progresses
Welcome to CO!!
if the 47X140098 is a partial VIN# stamped on the block:
4 = Buick
7 = 1977
X = Fairfax, KS GM plant
140098 = VIN sequence
Is it a 403? What's the casting number between the water pump & intake?
4 = Buick
7 = 1977
According to this page:
http://tech.classicoldsmobile.com/39.shtml
that casting number indicates a '77 to '79 403.
BTW, you should hop over to the newbies section and post a hello to introduce yourself to the larger CO audience than just the ones viewing this thread.
For a street driven car, why would you want to give up the extra 53 cu in? The alleged shortcomings of the 403 are only an issue in extreme driving (i.e., making the car a dedicated drag racer).
First time I've seen that. I stand corrected. Prior to the 403 though I'd suggest you won't find that casting. They might as well have just cast "SBO" on the side instead of 403. That would have been less confusing to some folks who argue that the 403 is a BBO.
Shouldn't your 403 be blue instead of gold?
Decided to look for more web images of this casting. Well apparently it's on both sides of the block to avoid confusion.
The casting of the motor size on the side was probably for quick reference at the machining and assembly plants. You wouldnt want someone to load a 350 gas block on to the machining line meant for the 403's, that'd be a quick way to ruin a block and the tooling. Diesel blocks have D or DX cast in the same area.
1BAD68"S"
September 17th, 2006 06:49 AM
