Correct idle speed?
Old May 31st, 2014, 05:57 AM
Gipper's Avatar
Correct idle speed?
While looking through the Tune up procedures in the factory service manual I see 2 different fast idle specs are given. (330 HC V8 - 4bbl carb with A/C)
In the text and tuneup chart it says to set idle to 850rpm with distributor vacuum plugged, but in the on car adjustment page it says to set the idle to 1100 rpm and that this is a new spec for 4 bbl carbs. 1100 rpm seems a bit high to me so my question is what do you guys set your fast idle speed at?
Brian
Gipper is offline
Old May 31st, 2014, 07:04 AM
Brian
1100 RPM fast idle speed with the car warmed up and the choke open (but with the fast idle screw on the fast idle cam) will NOT be that high when the engine is still cold and the choke is closed. Keep in mind that it is extremely difficult to exactly meet the cold conditions while setting this idle speed, as the engine is constantly warming up when it is running. The factory simply selected an equivalent fast idle speed to be set with the engine warm that will give you the correct speed when the engine is cold.
joe_padavano is offline
Old May 31st, 2014, 07:14 AM
Brian your idle speed should be 500 in drive, I've found sometimes 550 if it's equipped with air conditioning. The 2 rpm speeds your referring to is the rpm for setting your timing.
oldcutlass is online now
Old May 31st, 2014, 07:28 AM
Just so we're all clear, is the O.P. asking about the FAST idle speed, set with the fast idle screw on the fast idle cam, or the CURB idle speed set with the regular idle screw? These are two completely different idle settings for different conditions.
Old May 31st, 2014, 07:33 AM
Brian
I was also looking at this statement Joe, where he stated the vacuum advance needed to be plugged. I'm assuming the notes he is looking at are for setting the timing.
Old May 31st, 2014, 08:18 AM
Gipper's Avatar
THis is what I am talking about......
http://wildaboutcarsonline.com/membe..._Section_5.pdf
Look at page 5-6 step 3. Near as I can tell it is OFF the fast idle cam so it is curb idle. Am I missing something? I also am pretty sure if I set to 1100rpm curb idle 500-550 rpm in drive is not going to be doable.
What do ya think?
Brian
Gipper is offline
Old May 31st, 2014, 08:30 AM
Those are 2 separate adjustments with 2 separate adjustment screws. Step 3, the fast idle overrides the curb idle screw and is operational only when the choke is engaged. Step 2 is curb idle, normal operating temp and the choke is not engaged.
Old May 31st, 2014, 09:00 AM
What do ya think?
To be clear, here is the illustration you are talking about:
It says clearly: "Fast idle screw on low step of fast idle cam, and against shoulder of next stop."
I'm not sure what you're confused about.
MDchanic is offline
Old May 31st, 2014, 09:45 AM
Gipper's Avatar
I think what had me confused is that the car is fully warmed up. Isnt the fast idle cam used to bump the idle on a Cold engine?
Thanks for the clarification.....you guys are great!!
Brian
Gipper is offline
Old May 31st, 2014, 09:52 AM
Yes, when the engine is cold, and you pump the gas pedal to set the choke, the arm swings over and the fast idle screw will sit on the step once the pedal is released. After the engine warms you bump the gas pedal the choke releases and the arm swings back out of the way and the other adjustment takes over for curb idle.
Old May 31st, 2014, 09:56 AM
Gipper's Avatar
I knew thats what is supposed to happen so it seemed odd to me that you would set the idle with the engine hot....Thanks again for the clarification.
Brian
Gipper is offline
Old May 31st, 2014, 09:57 AM
Yes, and as I noted above, by the time you finish setting the fast idle, the engine won't be cold anymore, so it really isn't possible to set it correctly under those conditions. This adjustment is much more repeatable if the engine is at normal operating temperature and you set the fast idle speed under those conditions. When the engine is warm, you have to manually place the fast idle screw on the appropriate step of the cam. The factory determined that if the fast idle is 1100 RPM when warm, it will be appropriately lower when cold.
Old May 31st, 2014, 01:03 PM
When the engine is operating properly, it gets to operating temperature and stays there indefinitely.
Therefore, operating temperature is an ideal temperature to specify for making adjustments of the type that would vary with temperature (such as idle and valve lash).
If not operating temperature, what temperature would be good? The temperature you would encounter on a winter day? Do you put it in the freezer if you are tuning it up in the summertime? "Room temperature"? But the car is outside. 70°? But what if it's 60° today?
Get the picture?
MDchanic is offline
Old May 31st, 2014, 01:19 PM
Get the picture?
Old June 1st, 2014, 07:27 AM
Gipper's Avatar
Thank you all for the clarification. You guys rock.
Brian
Gipper is offline
Christophe2m6
October 27th, 2014 01:01 PM
Seff
September 20th, 2012 04:46 PM
73rocketship
July 6th, 2012 06:45 AM
|-K|=K
December 22nd, 2010 01:35 PM
awdavis01
May 30th, 2007 04:56 AM
Quick Reply: Correct idle speed?
